velvetfoot said:
Or, if you heat with oil, you could get a diesel generator.
...except that diesel generators start at about $10K.
I finally got to burn in our genset last month after a huge windstorm knocked us out for about 42 hours. It was kind of warm and I was mostly concerned about food going bad. I have a transfer switch that lets me dump the whole house on the generator and run anything I want, within reason. We ran a 2 ton heat pump, a big chest freezer, 22cf refrigerator, all the CFLs I could turn on, 3 computers and network equipment (DSL stays up in a power failure, BTW) and had enough for intermittent loads like the sump pump without worrying about anything tripping. We ran for about 16 hrs/day for 2 days and my gas bill went up about 30 therms over our usual gas consumption for the month. It works out to about $1.50 an hour, not bad for having the AC on! I've found that it takes a lot of gas just to spin it over, so if you are going to run it, you might as well run it hard.
Just to see what it would do, I turned on the 4500 watt hot tub heater along with AC and was able to pull the generator down to 50 HZ at wide open throttle with just electrical draw. It ran this way for about 5 minutes and nothing tripped. I was also able to start the 3 HP log splitter without a problem and it has a 60 amp inrush. We have gas hot water and range, so they are no issue, but my parents are all electric and report no problems. You have to be careful when the water heater is on, but the surface elements on a cooktop are only about 1800 or 2400 watts each and aren't a big deal when you have 8500 watts available.
We both have Kohler 8.5 RMY generators that were superceded by the RES generators, but same specs; just more bells and whistles. My father reports that his burns about a gallon of LP an hour, which is cheap if you consider the consequences of frozen pipes, bad food or a motel stay. They have lost power for 9 days at a time and it isn't unusual to be out 2-4 days. We used to have to worry about keeping large quantities of gasoline around, but now a 120 gal tank will hold him long enough to ride out most problems and call in a delivery. I woulda gotten a bigger tank, but...
(broken link removed to http://www.kohlerpower.com/residential/detail.htm?sectionNumber=13561&categoryNumber=13061&prodnum=54361)
These things are really commercial duty units and the 8.5 kw actually has a 12 kw head on it with a smaller engine. It has an electronic governor and voltage regulation on it that is top notch and should be almost impossible to burn out. I think these list at $3600, but I've seen them online for under $3000. It's definitely overkill for me in the 'burbs, but out in the boonies, this thing could literally be a lifesaver. I don't sell them, but I know a few people that have them and all are happy they spent the big bucks. The automatic transfer switch is a luxury, but if you travel and leave the house unattended, or have someone sick or elderly at home, you can be pretty sure you aren't going to lose power for more than about 30 seconds. They have a 5 year warranty on them now, so they must be pretty good, then.
BTW, I've noticed that whenever they talk about how many houses can run on a megawatt, it works out to about 10 kw per house. Obviously, you can get by on a lot less, but just make sure you can start your well pump, or you might as well not have it, IMHO.
Just my .02
Chris
