I have a detached garage with a chimney that I plan to get repaired and capped with a concrete cap like that on the house in the coming week.
![Garage Chimney Repairs & Planning Ahead Garage Chimney Repairs & Planning Ahead](https://www.hearth.com/talk/data/attachments/328/328117-31a0e025f420987ed91b84dd0ab249ed.jpg)
I think I want to put one liner in each floor of the chimney planning ahead for whatever various thinks could possibly be done inside this garage that has a 100 amp power panel, natural gas, water and sewer and also houses the pool pump and filter stuff. I hope to build a bathroom in there and maybe create a guest house some day.
But now I need to protect the chimney and it’s stucco. Water obviously enters the chimney and shows cracks in the stucco every time we get a lot of rain. I have a great stucco and chimney guy that is willing to do the work, but I want to make sure I choose the right chimney liner materials for this all masonry chimney:
- double wall?
- Terra cotta?
- stainless?
- galvanized?
- aluminum?
- vermiculite?
While I understand as a GARAGE the space may not legally house a wood stove, I could see possibly getting around that in the future somehow, like maybe removing the garage door, or dividing interior space. You never know.
Now upstairs, the floors are wood. And heat rises so well, I don’t see ever installing a fireplace or wood stove upstairs. Maybe a heater, water heater etc could possibly go upstairs.
So maybe two different types of liners should be installed. Then fill with vermiculite. Then somehow block off the top around the liners with some non-flammable material. I’m thinking of something like plywood but obviously not plywood. Maybe concrete tile backer board would work well. Then the chimney can be capped with concrete like the house.
![Garage Chimney Repairs & Planning Ahead Garage Chimney Repairs & Planning Ahead](https://www.hearth.com/talk/data/attachments/328/328118-3ef244522c54ffcf681dc37556e5c879.jpg)
wood stove? Well, it would be wonderful to be able to have an open fireplace which would require a big flue. Right? I’ve only really got a max of ~8”x8” x2 that I can fit in the chimney. Maybe that’s plenty. Just do terracotta?
My chimney guy is ready to start, but I want to make sure this gets done right. I will post some video I took.
- double wall?
- Terra cotta?
- stainless?
- galvanized?
- aluminum?
- vermiculite?
