E
		elkimmeg
Guest
301.9 Fuel types. Fuel-fired appliances shall be designed for
use with the type of fuel to which they will be connected and the
altitude at which they are installed. Appliances that comprise
parts of the building mechanical system shall not be converted
for the usage of a different fuel, except where approved and
converted in accordance with the manufacturer’s instructions.
The fuel input rate shall not be increased or decreased beyond
the limit rating for the altitude at which the appliance is
installed.
This code is not part of what was asked of me in the original post but this guestion has come up often concerning bedroom locations. In the past my state based their Mechanical codes on the 1993 Boca Mechanical with the adoption of the 7th edition we now aew part of the International code community. All these codes I had not looked into before but the 2003 and 2006 International mechanical codes have the updates that answer many past questions.
SECTION 303
EQUIPMENT AND APPLIANCE LOCATION
303.1 General. Equipment and appliances shall be located as
required by this section, specific requirements elsewhere in this
code and the conditions of the equipment and appliance listing.
303.2 Hazardous locations. Appliances shall not be located in
hazardous location unless listed and approved for the specific
installation.
303.3 Prohibited locations. Fuel-fired appliances shall not be
located in, or obtain combustion air from, any of the following
rooms or spaces:
1. Sleeping rooms.
2. Bathrooms.
3. Toilet rooms.
4. Storage closets.
5. Surgical rooms.
Exception: This section shall not apply to the following
appliances:
1. Direct-vent appliances that obtain all combustion air
directly from the outdoors.
701.3 Circulation of air. The equipment and appliances within
every room containing fuel-burning appliances shall be
installed so as to allow free circulation of air. Provisions shall
be made to allow for the simultaneous operation of mechanical
exhaust systems, fireplaces or other equipment and appliances
operating in the same room or space from which combustion
and dilution air is being drawn. Such provisions shall prevent
the operation of such appliances, equipment and systems from
affecting the supply of combustion and dilution air.
918.6 Prohibited sources. Outdoor or return air for a
forced-air heating system shall not be taken from the following
locations:
locations:
6. A room or space containing a fuel-burning appliance
where such room or space serves as the sole source of
return air.
1. Closer than 10 feet (3048 mm) from an appliance vent
outlet, a vent opening from a plumbing drainage system
or the discharge outlet of an exhaust fan, unless the outlet
is 3 feet (914 mm) above the outdoor air inlet.
2. Where there is the presence of objectionable odors,
fumes or flammable vapors; or where located less than
10 feet (3048 mm)above the surface of any abutting public
way or driveway; or where located at grade level by a
sidewalk, street, alley or driveway.
Exceptions:
1. This shall not apply where the fuel-burning
appliance is a direct-vent appliance.
2. This shall not apply where the room or space
complies with the following requirements:
2.1. The return air shall be taken from a room or
space having a volume exceeding 1 cubic
foot for each 10 Btu/h (9.6 L/W) of combined
input rating of all fuel-burning appliances
therein.
2.2. The volume of supply air discharged back
into the same space shall be approximately
equal to the volume of return air taken from
the space.
2.3. Return-air inlets shall not be located within
10 feet (3048 mm)of any appliance firebox
or draft hood in the same room or space.
3. This shall not apply to rooms or spaces containing
solid fuel-burning appliances, provided that
return-air inlets are located not less than 10 feet
(3048 mm)from the firebox of such appliances.
installed.
SECTION 303
installation.
rooms or spaces:
1. Sleeping rooms.
2. Bathrooms.
3. Toilet rooms.
4. Storage closets.
5. Surgical rooms.
appliances:
locations:
locations:
return air.
Exceptions:
therein.
the space.
