Ok, here is my recipe for logs. First, the paper wrapped ones:
Take a full sheet of newspaper, folded like a closed book, and begin rolling it around the pvc with at least an inch hanging off of the end. Make sure you have enough pvc uncovered on the other end to get a good grip to pull it out with later.
![Fringe Benefit of Having a Wood Burner Fringe Benefit of Having a Wood Burner](https://www.hearth.com/talk/data/attachments/84/84141-16274b90c9c897be4483fb95f77848e3.jpg)
Push the excess inside of the pvc and tamp down to create a plug.
![Fringe Benefit of Having a Wood Burner Fringe Benefit of Having a Wood Burner](https://www.hearth.com/talk/data/attachments/84/84140-e7abb0b2476c2880eb29c88da4e15564.jpg)
Add paper, leave, sawdust, coffee ground or whatever burnable you like and lightly tamp. Tamping too hard will make the pvc impossible to remove.
![Fringe Benefit of Having a Wood Burner Fringe Benefit of Having a Wood Burner](https://www.hearth.com/talk/data/attachments/84/84139-33d0dccebb83e8f7b62ad6ecc37c6326.jpg)
Once full turn the whole thing over with tamp in place, grip the plug end to hold it secure and pull down on the pvc to remove it.
![Fringe Benefit of Having a Wood Burner Fringe Benefit of Having a Wood Burner](https://www.hearth.com/talk/data/attachments/84/84138-ee8875ac3e4c8711df14c995476cc80e.jpg)
Then simply fold the excess newspaper over the end to seal.
![Fringe Benefit of Having a Wood Burner Fringe Benefit of Having a Wood Burner](https://www.hearth.com/talk/data/attachments/84/84137-9422dcb3847abcee4bd4c6c3cf1c0c99.jpg)
To make one with a paper towel roll simply tamp a piece of paper inside to make a plug and then fill as before and crimp the ends shut.
![Fringe Benefit of Having a Wood Burner Fringe Benefit of Having a Wood Burner](https://www.hearth.com/talk/data/attachments/84/84135-345fb15f82773c4287d80810f6cdac8b.jpg)
And here are what the finished products look like. The paper towel rolls are much denser because you dont have to worry about removing pvc. Think of them as your hardwood.![Fringe Benefit of Having a Wood Burner Fringe Benefit of Having a Wood Burner](https://www.hearth.com/talk/data/attachments/84/84134-5c2131a6e190d23f6054bb36e11064ac.jpg)
![Fringe Benefit of Having a Wood Burner Fringe Benefit of Having a Wood Burner](https://www.hearth.com/talk/data/attachments/84/84136-7ceb1d43477e70742c164525fcb64eb2.jpg)
