No worries, in 10 years you all will be driving EVs, and this maintenance nonsense will be much less.
No plugs, no pistons, no crankshaft, no timing belt, no fuel injectors, no fuel system, no muffler, no exhaust system, no cat, no tranny, no oil pan/pump/oil changes (sealed bearings), no alternator, no starter motor, little brake wear (regen brakes).
Has a 1/2 size 12V lead acid battery to run the on board computer and buffer the 12VDC powered accessories, run by a 3000W 12V supply powered off the 440VDC traction battery. The 12V batt had no trouble booting the computer at 5°F, it started right up.
Scheduled maintenance on my 2013 LEAF is:
--Rubber parts: wipers (still ok after 2 years) and tires (the torque and weight EAT LRR tires, I will be lucky to get 25k miles)
--Cabin air filter every 15 k miles or annually.
--Brake shoes, as needed, rarely. Change brake fluid every 30k miles.
--Replace coolant every 125,000 miles or 15 years (cooling system is about 1/5 size of an ICE car)
Early adopter problems:
--the 2013 model had an AC system defect/recall (leaked all refrigerant in about 12-20 mos), warranty repair.
--EV batteries are still expensive and small. My 2013 will need a new battery pack at 80,000 miles or 7-8 years of age (best guess), current replacement cost is $5500.
This cost works out to be 6 cents/mile, which is higher than my 'fuel' costs, which are about 4-5 cents/mile.
I"m leasing, so I'll never pay to replace the battery. Newer EVs with bigger batteries will go longer between battery replacements (figure 1000 cycles, or 1000x full EV range), and the battery costs (per mile) will keep falling.
