So in my old house the original fireplace is in a great central location, however the previous owners elected to remove the chimney rather than repair it. This has posed me with a pain in the rear for installation as most stove shops don't want to deal with it and just keep trying to sell me on a pellet stove which I don't want.
I am planning on having a core driller come out and core drill an 8" hole through the top of the fireplace into the firebox and running metalbestos down to the firebox and up the outside of the house and through the roof and then boxing it up against the house and fake brick facading it. I have checked with the local building inspectors and this would be to code as long as I keep the metalbestos clearances ok.
What I am trying to find is a freestanding stove that I can insert into my masonry fireplace and pipe up through the new chimney. The issue I encounter is that my fireplace is a good old fireplace with angles and I worry about having enouigh room.
I am looking for some options on stoves to install here, these are the measurements of the opening: 30" W, 28.5" tall and 22 1/2" deep in the center (an 18" wide section is flat at the back then it tapers inward as it goes out to the edges.) It is hard to describe maybe I need to draw a picture and host it.
Anyway, the hearth is 18" from the front of the fireplace to the front of the tiles, I would ideally like a stove that fits in the fireplace and I don't have to extend the hearth in front. I have been looking at the Englander 13-NCL it appears it would fit perfectly but I was wondering if there is one that is oriented about 90 degrees off so you would be loading wood lengthwise and have a narrower stove.
I really like the look of a freestanding stove with legs and a window.
Please recomend some stoves that might work for my situation, I also like the idea of a soapstone sided stove or cast iron or somthing to that effect so that it would retain heat well.
Also does anyone see any major flaws with my plan??
Thanks!!
Thanks!!
