I was also thinking about getting some chicken wire and try to square and level up everything with some thinset, anyone think I should or shouldn't do this?
then
Sorry I couldn't be of help.I have busted it far as I can go. If you look in the picture on the right you can see another clay flue, and on the left that is firebrick for the fireplace directly on the other side. The house had two fireplaces offset just enough from each other to follow the same angle.
So that is all I am going to have to work with.
I have a question for those of you who have installed free standing stoves into masonry fireplaces.
We had to have so much hearth pad in front of the stove door.
In your installations, I see the front of the stove nearly flush with the edge of the hearth.
I don't mean to be rude, but is that OK? Does it meet code? It was my understanding that the purpose of having X number of inches of hearth pad in front of the stove door was to protect from sparks and from chunks rolling out of the stove door. It looks like chunks or sparks could fall right out and into the carpet in front of the hearth.
Per above, I don't mean to be rude or confrontational- I'm just trying to understand.
In my case it's tile on concrete, some people build something non combustible in front whatever length and width requiredI have a question for those of you who have installed free standing stoves into masonry fireplaces.
![[Hearth.com] Freestanding Stove in Fireplace. [Hearth.com] Freestanding Stove in Fireplace.](https://www.hearth.com/talk/data/attachments/146/146954-3666db9187dc759e610cd13742a2054a.jpg?hash=45Wd0Axp-z)
![[Hearth.com] Freestanding Stove in Fireplace. [Hearth.com] Freestanding Stove in Fireplace.](https://www.hearth.com/talk/data/attachments/146/146955-bf78b6aa63937a8b3e976e6fe95c3433.jpg?hash=45Sa87X_xv)
![[Hearth.com] Freestanding Stove in Fireplace. [Hearth.com] Freestanding Stove in Fireplace.](https://www.hearth.com/talk/data/attachments/146/146956-0aeb86350cd97778db0cb1e9b488aab7.jpg?hash=2qTlSt6byg)
![[Hearth.com] Freestanding Stove in Fireplace. [Hearth.com] Freestanding Stove in Fireplace.](https://www.hearth.com/talk/data/attachments/146/146966-57b49e100b864b017ff1ff9a1add6b2c.jpg?hash=XYYjp40wuW)
Why?
This is the same thing that limited my choice of stoves. I had to find the stoves where the flue opening was furthest to the back of the stove.
I don't know if the fan sticks out the back of the summmit, but that needs to be considered too. I ended up having to put a slight bend in the liner, but no elbow.
It's 15" from the back wall to the edge of the lintel on mine. Even if I could've gotten a stove like the summit in there, it would've had a 30 degree elbow coming right out of the stove vent opening.
Sounds like you'll be getting an insert, unless you can wear her down. Sometimes they come around sometimes they don't. You could always tell her that an insert just won't fit.
The only reason I can think of is appearance. I was determined to have a straight pipe come out of the stove just because of the way it looked, ease in cleaning was a factor too, but not as much. And the wife would have said "that doesn't look right", no doubt about it.Mine is about 18" from the wall to the lintel. And using a 30 right from the stove is the only option I think. If it works would there be any reason not to do that?
