Friend who no longer burns wants to give me a bunch of wood that's been stacked for several years and has termites and probably carpenter ants in a good portion of it.  Take it or leave it?
			Den said:Well, it's a big stack, 3 - 4 cords, of hardwood.
How did you tell which were female, for spaying?I spilt, spayed and stacked it...
   But seriously folks, I appreciate all the good advice.  Assuming you meant that you sprayed it, with what?Den said:I already have 1 load of it sitting in the truck. I tried to cherry pick, but did take some that had been chewed on by bugs, if it still had some weight to it. I'd hoped it would be okay after tossing it into a pile by the truck and banging splits together several times before loading. When I went to unload the next day, ants were visible on top of the load, and I found termites inside a cracked split. That's when I figured I'd consult with the brain trust here before proceeding to unload. We've had carpenter ants before, and these are smaller. I guess I'm mostly worried about the termites. Then again, we live in the woods, so it's pretty unlikely that there aren't any termites already around here. . .Anyhow, I deployed the bed cover last night before it rained,
I already have 1 load here. . .was going to stack on treated 4x4's. Is that high enough off the ground? How far from the house should I keep it?andybaker said:If you can stack it away from the house up off the ground, should be ok. Or, leave til next winter and bring over when you need it.
