12 in SE CT with wind blowing 20 something off the water. It took forever to get the stove hot but it was heating 750 sq ft first floor from 50.. over 1 1/2 hours to get to 500 should have thrown in a lot more kindling coals or not.. Lesson learned.
2 degrees this AM around 6:30. 72 downstairs now. Darn the coals though. Had to remove some perfectly good coals this AM to get in a bigger load. What I need is a big stove...oh wait a second, I CAN'T.![]()
How do you deal with the air required to run 2 stoves.Must be a decent volume of fresh air needed to service 2 wood stoves.IF your house is at all tight this could translate into poor draft if your running with a constant air deficit inside. Seems an OAK would be a must with 2 stoves. I have 1 large stove, an OAK and a very leaky house so i know my stove is not starving for air.About to pack the 13, and hope for the best. That's my worry, but I think I'll be OK for the night.
Packing the PE right afterwards........... not worried about that puppy by a long shot.
I realize this was directed at the OP but when you have chimneys that are 35-40' no house is tight enough to limit that kind of draft. Not only do I have dampers full closed in both at all times I really need a second one inline for the basement stove.How do you deal with the air required to run 2 stoves.Must be a decent volume of fresh air needed to service 2 wood stoves.IF your house is at all tight this could translate into poor draft if your running with a constant air deficit inside. Seems an OAK would be a must with 2 stoves. I have 1 large stove, an OAK and a very leaky house so i know my stove is not starving for air.
Same here ,anything above 40 and i cant use the stove at all,even the lowest setting will cook me out.I'm LOVING the deep cold we had last night. It lets me load up the PH and let it rip. I loaded with a 3/4 load of mostly red oak last night, got a nice 13 hour burn and the oil heat never came on. I have the opposite problem, when it's upper 30's and 40's, I have to keep the fires small or I'll cook/have to open windows!
Bring it on baby!![]()
Sounds like a BK that you can control on a full load is just what the doctor ordered.
Hard to beat a stove that can be dialed in to the output you want any time you want and even vary the output during the same burn.
Woodstock specifically cautions AGAINST elevating the wood. It needs to sit on the firebox floor. I think too much air gets at he wood otherwise and it burns too hot.I had for years did some heating with a coal stove in my basement - I used NE anthracite coal, great stuff for heating. The stove had, as required, a shaker grate that if used carefully allowed for removing ash into a pan, which I left to cool before removing from the stove. I realize coal burns from the bottom up, not top down like wood, but I assumed some wood stoves also have a shaker grate with a pan underneath.. maybe that is the solution. My QFire Insert has to have ash removed from the top, and out the door.
![[Hearth.com] Freaking Freezing Ouside, And Running Both Stoves.... [Hearth.com] Freaking Freezing Ouside, And Running Both Stoves....](https://www.hearth.com/talk/data/attachments/94/94185-1d053640d002e507bd4a50951704c94c.jpg?hash=Sl5JGA4KJ1)
It was 12° F with NW winds 35-40 knots at first light. The house dropped to 68° in the main rooms, 63° at the extremes before I re-loaded the stoves. Actually turned on the oil fired boiler for 15 minutes to warm the pipe chase in the unheated garage. Back up to the normal low 70s now.
The cold is OK and I can deal with the wind. The combination of both at the same time last night was a killer...
KaptJaq
You must have either a very short chimney,or a pressure difference caused by a tight house and no OAK. I never have to coax my chimney to draft.Upstairs 75downstairs 70
. I had a heck of a time getting the chimney to draft, I had a portable heater warming the stove/chimeny for 3 hours to get it to start drafting enough to start a fire. It is PITA to operate 2 stoves in extreme weather.
Stay warm my friends .......
