ETA: The storm is also sucking up a lot of dry air and has been for some time.
So that will weaken it?
The latest from map from Weather.com showing the placement of Hurricane and Tropical force winds shows that the impact to Maine is less and less. Fingers crossed so that more help can be sent to those states hardest hit.
I just ordered one from amazon.(water powered sump pump) Will be delivered tomorrow.
What model did you get?
My neighbor has one and I thought it was slick as chit. I have a Watchdog battery back up (Both pumps, connected together) but it doesn't keep up with heavy rain. Luckily I haven't needed it yet? (Had a bad flood about 7-8 yrs ago and didn't have one) But I have tested it on heavy flow days and it is about half of what the Main pump is.
Thanks...
God bless everyone in the path of this Monster
Its a liberty pump. Specs say it can pump 1000 gal an hour at 4' lift depending on water pressure
My lift is only about 2' so it should do the job.
Ill be hooking it up tomorrow morning. I hope my pluming supply is open as i need a few parts.
It might save me a flooded finished basement. I got a lot af expensive stuff in there,a bar ,pool table,wood stove ect ect.
Unfortunately, the weather map show us in direct path, I am pretty shure you made a good purchase that you will use. Good luck stay safe.
The storm continues to deepen and strengthen this morning. There will be no weakening until landfall. As you said Smokey, the storm surge in NJ and NY will be the big story but widespread power outages from the mid atlantic all the way to New England will be a significant story as well.If it does it long enough yes it will weaken it, the storm however is very large and is also going to shortly merge with the one out of the Midwest. Currently the most watched aspect of the storm is rain and surge potential as this causes flood related issues.
How did you do over the weekned?I'd rather be fishin!
True!Real slow, Only caught a few. Still had fun, Any time we get out is good.
