They both appear to fit. Which of these two stoves would you recommend? Thanks for your help. I will be getting an insulated liner and having a block off plate installed. The downstairs of the house is about 1600 sqft.
A couple observations...Combustor on the Regency looks better-protected, and they say you can use a 5.5" liner.
I have seen the regency, but not the FPX. I like the regency, but have had great difficulty finding a dealer, so i started looking at a backup and came across the FPX. How many settings are on the fan?I'm heating 1900 sq.ft. in CT with FPX for third year. I wouldn't pay attention to advertised burning times .Happy with my insert so far. If installed right with dry wood will do the job.It is a good looking unit. Did you see FPX and Regency in person?
You can dial any speed you want or shut it off. My wife uses it all the time and sets speed appropriate to what she feels is neededI have seen the regency, but not the FPX. I like the regency, but have had great difficulty finding a dealer, so i started looking at a backup and came across the FPX. How many settings are on the fan?
Thanks for the info. I live in NY, right across the CT border. Did you get an insulated liner and install a block off plate? I have not heard as many disappointed users with this stove as there were for the Regency. So, I am really starting to lean toward this unit. But, need the right installation.You can dial any speed you want or shut it off. My wife uses it all the time and sets speed appropriate to what she feels is needed. There is many faceplates and surrounds to choose from so you can find something that fits your décor.
I have an exterior chimney. One installer I spoke with today stated that he does not like insulated liners, that he insulates the top and bottom of the chimney and that is plenty. He also stated that he like a corrugated liner because it flexes and doesn't allow creosote to build up. There is so much variation in this industry it scares me. Were you happy with your installer and are you close to Danbury?After reading this forum I went with insulated double wall smooth liner and don't regret it. I had a very little of creosote buildup . Next to none. The unit burns extremely clean but I think insulated liner helps.So, don't listen to installers that say you don't need it. Same with block off plate. Do it when installing, do it right. I've skipped on it when installing, planned to do it later. It's been three years..... I have crazy amount of Roxul staffed up to the chimney around liner , though. I hope I will find time to do it this year. You can insulate the firebox around insert with Roxull as well. Do you have interior or exterior chimney?
There have been several reports here of the two-ply liners separating, so I got a single-ply, HomeSaver Heavy Duty Roundflex. It's heavy but with only 16', my nephew and I were able to pull it up from the bottom.Ask your guy if he ever heard of flexible liner with smooth walls
My ash window leads to outside. I do have basement, but the window goes to outside. Did you just plug it into an outlet in your basement or is there some other wiring kit involved?The wire next to the unit would not look good to me .Its a flush unit and looks like real fireplace , the wire would not be approved by my designer/wife. I have wired it trough the ash window in masonry fireplace from basement. It has option of wiring it on left or right side which didnt matter in my case.
Can you clarify? I see some people end up with an outlet inside the fireplace. This does not seem like it would be allowed. But, somehow, people are getting their set ups to where you don't have a cord protruding into the room. The FPX large hybrid brochure shows no wires and they state that they have a wiring kit. I called one dealer and he stated that they can go out an ash window into a basement.The appliance needs to be plugged into an outlet in the room for servicing. An alternative is to have the outlet switched from within the room.
https://www.hearth.com/talk/threads/its-coming-together.157143So, what is everybody else doing to get the wires hidden. I thought I even saw where someone had an outlet inside the fireplace.
Do you want to do it yourself or planning to hire someone ?My ash window leads to outside. I do have basement, but the window goes to outside. Did you just plug it into an outlet in your basement or is there some other wiring kit involved?
I have an outlet outside near the ash window clean out door. Could I just plug it in to that outlet during the winter months and then put the cord back into the clean out area during the off season? Or is it allowed to drill a hole into the basement from inside the ash clean out?
How do you remotely mount the fan?That's one reason I went with FPX, b/c you won't see the hideous wires. Also, the fan is variable speed and when remotely mounted you barely hear anything, very quiet.
