ThePhotoHound said:If there was any remaining porcelain in the chamber, I'd hear it, even when idling, right?
No, you would have a hole in your piston
ThePhotoHound said:Babalu - I take it that means I'd definitely know it if something was in there?!
Struggle - Sorry for my ignorance, but what does a misfire sound like? When the motor is idling, I can't hear a thing.
keyman512us said:ThePhotoHound said:keyman512us said:ThePhotoHound said:While we're on the topic, any ideas to fix a gas pedal that sticks a little? When you go to give it gas from a standstill, the pedal sticks ever so slightly...
Are we still by any chance talking about the 'exploda'....lol
Yes, sir
Perhaps we will re-visit this latter...gotta run (Got some miles ahead of me on my favorite MAss playground...I-495)
Yesterdays trip to Gooses' homestead encountered this little gem... I would love to have choked this idiot and asked him "Hey driver what genius outfit do you drive for and what moron told you to run an over dimension load up 495 through the Lowell Connector in the 5 o'clock rush hour...You got a death wish or somethin???"
Perhaps I wasn't all that courteous to "our guest to this state" but hey read the motto on the license plate...
The only thing worse than some chuclke head running the hammer lane, pulling a camper with the whole family on board with the cruise control set at 65 is these crews hauling a demo pile in the making...
GVA said:MO Mass has some pretty tight inspection requirements now... Unfortunatly any play and I mean any play in the ball joints will cause a failure.
It sucks....... It like failing because your window doesn't roll up tight anymore......
ThePhotoHound said:Mo - Great advice. Thank you for your input. Struggle - I have most of the tools... I just need a ball joint press and fork.
I forgot to mention that 1 -2 inches on the inside of each of the front tires is BALD. I mean bald. The rest of the tread is approx. 1/2 gone. When he moved the wheel, it had a good 3/4 inch to 1 inch of play in it (on the passenger side) and very little on the driver side. That leads to another question:
He (mechanic) said that it was most likely the upper that was the culprit on the passenger side, and that the lower might be OK. For an extra $30, doesn't it make sense to do both at once? If I'm not mistaken, shouldn;t you remove the lower to properly press the upper back in anyway? And furthermore, even if the driver's side is passable, should I just replace those as well? Or does it not matter?
Thanks.
ThePhotoHound said:I forgot to mention that 1 -2 inches on the inside of each of the front tires is BALD. I mean bald. The rest of the tread is approx. 1/2 gone. When he moved the wheel, it had a good 3/4 inch to 1 inch of play in it (on the passenger side) and very little on the driver side.
No it's not a stretch when you bring the truck to 2 shops and they won't replace them cause they don't have enough play to warrant replacement from a MECHANICAL standpoint. But from the inspection station perspective when they put that 5 foot pipe under my trucks front tire and practicaly lifted it off the jack they saw a little play and failed it...keyman512us said:GVA said:MO Mass has some pretty tight inspection requirements now... Unfortunatly any play and I mean any play in the ball joints will cause a failure.
GVA...That one might be a stretch. If the window lets go... it's doubtfull it will send you off the road straight for a tree or worse a minivan loaded with kids on their way to a soccer game.
While properly maintaining a vehicle is important....If I had to choose between having to control a vehicle with no brakes or no steering... I would choose the no brakes.
I think most professional truck drivers would agree with the above statement.
At least if you can steer... you still have some control.
It's been different stations each time :-SMo Heat said:GVA, Time for you to find a new inspection station. You've got a rough crowd! And don't forget to bring a fruit basket for the inspector. :lol:
