I'm not sure I understand the negative pressure thing. Can you explain it better?
Yup, that is the basics of it.If your return air does not have an unobstructed path back to the furnace, the blower could in effect try to pull air down the chimney. Quick dirty & simple explanation.
Sure, there are a number of Tundra owners here, what do you wanna know?Can you tell me anything about the furnace?
They say so...we'll see.Did drolet get all the issues ironed out?
Yeah, you have the idea. I used a 15 minute bathroom fan timer. The factory switch works but the timer is just a convenience factor, or idiot proofing in some casesI also read where someone was using a sauna timer and a thermastat. Is this so when you fire a new load. The draft can be open untill everything is up to temp.
Yup, pretty much. You need to test before the pipe damper, not after. If you have the Dwyer manometer it will need to be flat and level, and zeroed out before putting the tube in the pipe. Get a short piece of metal tube to attach the meter hose to, then that goes in the pipe, not the hose, seems obvious but people have done it.When using the manometer. You just drill hole into black stove pipe and check draft. This is done after chimney is up to temp?
My serial number is 1144.
Starting to think I should of saved up for a better furnace.
Yeah, 26, 28, whatever they stock works fine. You are gonna run (3) 8" runs? Drolet recommends only using 2 of the duct connections, preferably the two on the sides. I'd do two main runs and just come off the 8" with 6" taps for the registers if you need multiplesI think I'm going to put two at one end and one towards end with bedroom and bathroom. What is standard gauge that menards sells? I would want to get 26 gauge 8" round pipe right? What kind of ctc would I need maintain?
Just do both...I didMan this furnace stuff is complicated! Maybe I should of put a insert in the fireplace
Ahh, hmm, I hafta think about that a bit. What would be the advantage?Can I run the two 8" pipes out of furnace then connect them to each other using 90* tees? Then do 6" pipe off of that? The 8" will run the length of house, but be feed with both pipes coming from furnace.
Could do a plenum like I did on the one I had.Just do both...I did
I guess I have WHAD (wood heater acquisition disorder)
