I feel for you! Wind chills -60f [emoji33] Time to break out your best wood! Stay warm
Yeah, I've been keeping an eye on the WI forecasts. I lived there 32 years and still have family and friends there...Hubertus and Cross Plains. I don't plan to move back any time soon, though.in southern WI and we're forecast for actual lows of -28 and -31 for Tuesday and Wednesday - wind chills around -55...I've been setting aside my nicest pieces of White Oak for a few weeks now thinking that I should save them for really cold weather - well this is it![]()
TN...dang, son, you're way down south, even compared to me. You're staying in the double-digits. Even your BK will be able to keep up.I feel for you! Wind chills -60f [emoji33] Time to break out your best wood! Stay warm
Ya Xmas I learned that lesson a long time ago.So I put the largest stove in the basement and the large stove on the first floor.This arrangement handles the type of temperatures that are coming my way.Rich - I was actually thinking I wish I had a second stove in the basement. I have a second flue connection down there, just never connected anything to it.
I have a LP furnace for backup and it really hasn't been run this year except to test it at the beginning of the season - I do think that will be called into service in the next few days!
It could be worse...you could be in MN.![]()
It's been in the minus 30-40*C range here for the last few weeks. I gave up and have let the furnace kick on to supplement the stove. way more comfortable now. currently sitting at a balmy -47*C! yikesRich - I was actually thinking I wish I had a second stove in the basement. I have a second flue connection down there, just never connected anything to it.
It's been in the minus 30-40*C range here for the last few weeks. I gave up and have let the furnace kick on to supplement the stove. way more comfortable now. currently sitting at a balmy -47*C! yikes![]()
I have a couple loads of ultra dry black locust in the on deck spot in the garage.
There's a little difference between Black and Honeylocust but they are both good. I never burned Honey but my neighbor has a dead one that I'll grab at some point. The Black coals like you can't believe!That's now CSSC and will sit for 3 years and then I'll get to burn my first Locust - it's going to be awesome.
A basement install also keeps my pipe from freezing.Two other things with the install that if the power goes out in below zero weather my two stoves running together will keep the house toasty.I know this works at -7 degrees with even colder wind chills.Since we don't get your kind of cold I don't know how they would do at -50 degrees.Another nice feature of my largest soapstone stone is that once it's fired up it'll give us 14 hrs.of usable heat which is enough heat time to feed the stove and not have the down draft effect that the basement will cause when the stove is fired from a cold start.So my advice to you would be to get a stove that will stay heated in the basement for as long for you to go to work and back home and long enough for you to get a good night's sleep before it cools off before reloading.This way you'll get no down draft.That's a great strategy. Most of my basement walls are insulated, so I know I'd lose some heat to those un-insulated areas, but most of the heat will rise up and heat my floors - that would be a big help!
I'm sort of coasting right now. It's -2 right now and that will be the high for today, but the sky is clear and I'm getting tons of solar. Reloaded this morning on good coals and just letting the coals sit for now. As we get into the afternoon it's supposed to get cloudy before it drops to -28 ... I'll start pouring the wood to 'er then.
i hear you on the 'principle' of avoiding the LP. my stove can do it, even in this weather, however we can really feel the drafts in the house, and the floors get really cold because of the cooler unfinished-on-bedrock basement. if it was just me, i'd stick with the stove - however, when the boss starts complaining, it's time to let the LP chip in.Now that is a stretch of cold! If we got those here, everyone would move out of Wisconsin!Still laughing at the, "...balmy -47*C!"
Over the 30 years I've lived here and heated with wood, out of principle i've done my best to not let the furnace run. Sometimes even with the old VC Defiant roaring, it would run once or twice day if we were below around -20F. I'm not being as "principled" in my old age - I'll burn some LP in this kind of weather.
And thanks for reminding me a little about the F - C conversions! Your -47C is my -53F! And I'd also forgotten that -40 is where C and F match!
Stay warm.
How is that Princess in handling those Temperatures ?View attachment 239571 Was outside for about an hour today. Extra bedding for all the animals. The fingers can only be outside the glove for a few minutes. Everyone is laying low.
