A thin hard layer of creosote in the primary chamber is normal and expected, and many feel that it actually seals and protects the steel from corrosion. But when too much accumulates on the door, it can become a problem for the gasket. It would be unusual for any quantity of creosote from a gasser to make it into the flue, but the "hidden" location for creosote formation is the boiler HX tubes. Again, a hard creosote layer in the tubes probably isn't going to do any permanent damage to the boiler, but it does impact the efficiency by reducing the heat transfer of the HX. If the tubes are never cleaned, it may also be possible for one or more to become completely blocked with accumulated creosote. I noticed that you posted today in another thread dealing with this issue, and would recommend (since you have a lot of idling) that you pull the top plate of your boiler and check the tubes for creosote. I speak from experience on this :sick:ihookem said:And that's why I get creosote in the morning. The only thing left to do is put small pieces in and run it hard to clean the box out and get the house back to temps a little faster. Does anyone think creosote takes a toll on a boiler? I think it does to some degree but I always have a hot boiler. I also think a hot boiler will last longer than a boiler going from cold to real hot to cold almost daily. What do the rest here think? Also, I asked about how long boiler lasts. Any stories on how long they last and how they were used?
Piker said:The bottom line is... if you're going to idle, your best to do it for longer cycles in order to produce lower deeper idle states and longer hotter burn states. Its the same idea as using a buffer tank.
ISeeDeadBTUs said:Piker said:The bottom line is... if you're going to idle, your best to do it for longer cycles in order to produce lower deeper idle states and longer hotter burn states. Its the same idea as using a buffer tank.
That seems contradictory. A buffer tank should even things out. But you're saying longer off and on cycles is better.
I need more explanation.
bigburner said:I think Piker is saying that : if you can keep longer idle times that the tar is generated in the early stages and when the air is removed for longer period that it will go dormant and make less tar. I am little confused on the 124 slab set back thing. I boils down to GPM x split, the temp is not a variable.[assuming there is sufficient load] More cooler water will work as fast has less hotter water and if thanks are low then more cooler water available. I know every one is different.
Piker said:ISeeDeadBTUs said:Piker said:The bottom line is... if you're going to idle, your best to do it for longer cycles in order to produce lower deeper idle states and longer hotter burn states. Its the same idea as using a buffer tank.
Gasifiers are at their least efficient when they smoke. They tend to smoke the most right at the points where the draft fan turns on before the coals and refractory are up to temp, and then again immediately after the fan turns off. By allowing the cycle times between fan on/fan off to be extended, you create a situation of higher highs and lower lows with less short cycling. This can be achieved by using some additional water volume on the system in the form of a buffer... or using a setback at night to allow the boiler to reach a very low state of idle where things cool down and minimal gas is escaping out the stack... when the temp comes back up again, the boiler has to work harder and longer to produce the required heat load, and thus a hotter burn and better secondary combustion is achieved.
I am not saying that idling is the best case scenario...
In a non storage situation does this still apply? are you saying if I use a "buffer tank" and add more volume of water it will improve my system and give me an additional 1-2 hours before loading again since it will idle more often and therefore quite possibly burn less wood (kinda like during shoulder months I load 2 times a day)
Musclecar joe
cheers
musclecar joe said:Piker said:ISeeDeadBTUs said:Piker said:The bottom line is... if you're going to idle, your best to do it for longer cycles in order to produce lower deeper idle states and longer hotter burn states. Its the same idea as using a buffer tank.
Musclecar joe
cheers
