I use a washer style thermometer shoved between the flue collar and the liner adapter. It reacts pretty quickly. I don’t know how the temps here compare to a probe 18” up but I base my behavior on the readings I get. At startup and through the peak I shoot for readings between 350 and 500. It often goes higher and I have the warning alarm come on at 600 to make sure the air is turned down and the fan is running. I suspect any location on the stovetop near the collar to inside the flue 24” up will give you good actionable intelligence as long as you customize your targets to your setup.
