Battenkiller said:Todd said:But you should care because you don't want to wreck your liner with a continuous burn over 1000 degrees internal which would be about 500 for your external thermometer.
Todd, I do believe the continuous 1000ºF UL safety rating is for the actual temperature of the metal, not the gas temps. I had the same single-wall black pipe for my old stove for almost twenty years, and I'm sure I consistently ran it in the 500-600ºF range all that time. That's because I was advised to by every expert I ever spoke to. It was in fine shape when I finally hauled it to the recyclers when I needed a larger capacity flue for the new stove. Exposure to 1000ºF is nothing for steel, especially stainless. The metal parts on the inside of your stove exposed to temps a hell of a lot hotter than that.
Oldspark, I'm certainly not attempting to show scorn for your concern, just poking you a little. I thought you knew me well enough by now I didn't have to put silly emoticons in there to let you know. I think you are showing a lot of intelligence for pursuing this the way you are, I just don't have the inclination to go back over all those posts to rehash it all. You've been at this long enough that I'm sure you'll figure out what you need to know sooner than later and all will be fine.
Yep, your partly right, it's 1000 flue temps for factory built fireplaces, but I think they go by internal flue temps not external, could be wrong tho? Can't find the UL rating for liners.
