Hello!
So this is my second winter heating with wood in my raised/split-level ranch using my Regency I3100. I absolutely love it but I do have a rather hard time with heat circulation. The insert is located in the fireplace in the lower level family room of my 1750 sqft raised ranch. The stove can keep the lower level at 80-82 fairly easily but I am having a very hard time getting the air up the open staircase to the 2nd level. The heat must move down a narrow hallway towards the garage and then turn and go up the main staircase with main doorway/entry landing. I have tried multiple fans on the floor on the top of the stairs the landing and even the bottom hallway to try and circulate the heat but the best I can ever get is around 70 at the thermostat in the hallway right on top of the stairs.
I have read every single possible post I could on here for putting in floor registers. I feel this is my best bet for getting a more even temperature in the upstairs living room/kitchen/dining room. According to all the post i've seen it seems recommended to install a fire damper within the register. Despite all the posts i've read I haven't actually "seen" a picture of how this would look or even how it is done. Does anyone have any pictures showing an actual installation of a fire damper for a register between floors? Does the damper float inside the metal duct sleeve or is it attached in the middle or how does this work? I am not an HVAC professional and will most likely try to hire someone if need be but would like to be able to explain to them what i'd need and make sure it's done correctly. Would I need a metal "duct/sleeve" to fit in the hole and then attach the damper in the middle? I was looking at the one's at either
Atlanta Supply Co:
www.atlantasupply.com
or
Grainger:
Would either of these work for a register through the floor/ceiling? Any help or examples from someone who has previously done something like this would be greatly appreciated!
I have attached a layout of my floorplan and possible locations for the registers as well.
Atlanta Supply Co:
Session Timeout :: Atlanta Supply Co. :: Air Diffusers, Vent Covers, Air Conditioning Vent, Vent, Air Vent
Baseboard Covers at atlantasupply.com. Your source for baseboard registers, floor vents, floor vents and vent covers.
or
Grainger:
