C
As I said in another thread - Woodstock has the best customer service in the wood stove industry !
Does that mean that if you stand with your feet together you are exceeding the weight limit?the floor was engineered to support 40 lbs per square foot.
Give it a rest. How many other stove companies sell direct?
I wish Woodstock made a smaller version of the Progress Hybrid but I might be able to make this work. Thanks again.
Better safe than sorry - good jobI used the pier block and short 4x4 columns to run a laminated 2x6 support beam mid span under the section of floor that supports the hearth. Using materials i had on hand from reno's. The adjustable saddles are a great idea - I couldn't find them here ( to be honest I didn't kill myself looking). I just sat the posts in the pier blocks ( designed to hold a 4x4 post or beam) and shimmed the top connectors. Pretty sure the floor wasn't going to fail but for a few $ and an hour of my time I have a floor I could set 5 stoves on. And zero noticeable bounce / deflection across an otherwise long span evken when big excited newf is chasing me towards the door at walk time Helps me sleep better, even though many would view it as overkill. Also a 3' crawl space, lots of room to work.
The floor is reinforced. The Progress Hybrid arrived this morning. After working with a pallet dolly, lifting straps, four healthy young guys and an older guy (me) the stove is safely on the hearth and assembled. I have to cut down a piece of the old single wall pipe that connects to my 8" outdoor stack and then install my new 6" double wall interior pipe. I'm hoping to finish the install Friday. It should be a warm January!Better safe than sorry - good job
