FLEX 'RIBBED' LINER VS. RIGID 'SMOOTH' LINER
Gil655
5
SW COLO
I was wondering if there was a noticable performance difference between the corragated flex liner and a smooth wall rigid liner.
you would think the smooth wall would provide more draft and be easier to clean. im trying to decide if the cost difference
between the two woukd be worth it. With the rigid Dura liner being more expensive
what are your thoughts
How much difference is the cost.. flex is easier to install also, but yes rigid does provide more draft, will you as a person know... Probably not, not unless comparing the two stoves side by side.
I was weighting the same decision when I did my install. I went with double wall insulated rigid and it was fairly easy to install.
Its a charm to clean. The only rough patch is the flax liner I have at the last 5 feet through the smoke shelf to the insert.
When I bought it, it was a few hundred more than a flex with the added cost of the insulation for the flex. For me, well worth the added expense.
Highburn,
I installed 20' of 6", 304 grade, 22 gauge rigid liner in an existing interior 8 x 12 clay flue. It is a straight shot into a thimble, so it was an easy install. If you burn properly, I would think that both flex and rigid would perform equally. Being smooth, I would think the rigid is much easier to clean. That said, I paid $550 for all the parts needed to complete my installation. I've seen flex kits as low as $350. I think the rigid is worth the extra money and will probably last longer.
Jim
