Yes and yes. Take off the right rear side panel three 1/4" screws and two just need to be backed out a ways. It is right in the exhaust and held in by a 1/4" screw. Pull it straight out and just wipe it off and clean it. You don't need to replace it if it's working. You could buy one as a back up and if or when yours does head south it's about a 5 minute job total. Getting the new one out, taking the panels off, and replacing everything. Unplug the stove 1st and let it cool so that adds time but the actual ESP replacement is quick and very easy.
Not sure but you likely have the black wire ESP probe so verify that so you get the correct one. Red wired ESP's are usually found on older stoves........but ya never know. I've seen where they have been switched up here or there. That requires different dip switch settings.
Go check it out. You should know these things.
