Hi Everyone and @BKVP,
We have had one of those rare Blaze King Ashford 30s with a stinky hinge. I observed that the knife edge close to the hinge was right at the edge of the gasket and under a lot more pressure than the latch side of the door gasket. We had wet wood last year (this year we have great wood), but it left a lot of creosote to demonstrate the issue.
This is the knife line on the hinge side, the knife is almost at the exterior edge of the gasket channel (pair of needle-nose pliers to show where the knife sits):
![Fixing Blaze King Ashford 30 door stink with Play-Doh Fixing Blaze King Ashford 30 door stink with Play-Doh](https://www.hearth.com/talk/data/attachments/264/264178-380d195f902ffe7052dad3ef6a7bdca4.jpg)
This is the latch side of the door. It rides closer to the center of the gasket channel:
![Fixing Blaze King Ashford 30 door stink with Play-Doh Fixing Blaze King Ashford 30 door stink with Play-Doh](https://www.hearth.com/talk/data/attachments/264/264179-6b2c7cc420a3e50ff48aab88197dfd7e.jpg)
I removed the gasket and rolled up some Play-Doh so I could see exactly where the knife edge was. Here is the hinge side Play-Doh impression:
![Fixing Blaze King Ashford 30 door stink with Play-Doh Fixing Blaze King Ashford 30 door stink with Play-Doh](https://www.hearth.com/talk/data/attachments/264/264184-9638047d08e82a16dc6d527b7a683a67.jpg)
Here is the latch latch side:
![Fixing Blaze King Ashford 30 door stink with Play-Doh Fixing Blaze King Ashford 30 door stink with Play-Doh](https://www.hearth.com/talk/data/attachments/264/264181-97510f88b7260cc07ddf85f978803c95.jpg)
You can see an opportunity to split the error left and right and put the knife edge more cleanly in the center of the gasket and gasket channel.
The ashford is a normal plate-metal stove with pretty panels that hang on the outside, these make it pretty and help with the stoves love clearances. Taking the panels off is pretty easy:
You will need the following items:
1. Metal BK Shims if you want to adjust gasket pressure at the hinge side.
2. Wood cedar shims to slide under the front door casting before you loosen it (or to change vertical alignment).
3. An 11mm wrench - seems you can take an entire BK Ashford 30 with an 11mm wrench.
1. Remove the temp probe and carefully lift the top off. It's held there by gravity.
2. Each side is held in place by 2 top bolts (2 each side), you loosen or remove these panels by lifting upward. There are two bolts at the bottom but they seem to be mostly guides (you can reach the back, bottom bolt with your 11mm if it's snug and give it a turn to loosen it).
Loosen these:
![Fixing Blaze King Ashford 30 door stink with Play-Doh Fixing Blaze King Ashford 30 door stink with Play-Doh](https://www.hearth.com/talk/data/attachments/264/264182-94e9eb19e8d0cec38c405cd1f7819247.jpg)
3. With the sides out of the way you can now loosen the front. Slide those cedar shims under the left and right side of the front panel, close to ash drawer until snug. This will stop the front from dropping - loosen the four bolts that affix the front casting - also be careful, the bolts are short, You have maybe 5-8 full turns before the bolt comes out and the factory spaces fall into some strange place (likey your ash pan). Either way they are annoying to put back in. In any case you need to back these out.
4. (optional) if you are installing BK spacers on the hinge side, loosen those bolts a bit more and slide the spacer between the stove body flange and the front casting. Here are the spacers. These are about 1mm thick, not much, but a little goes a long way.
![Fixing Blaze King Ashford 30 door stink with Play-Doh Fixing Blaze King Ashford 30 door stink with Play-Doh](https://www.hearth.com/talk/data/attachments/264/264183-25664be2d43002d202727cec6f1a9e1f.jpg)
5. Slide the front casting relative to the stove (in my case I needed to slide the front in the direction of the hing (to the left)) to center the knife edge relative to the gasket slot. (Note: Be sure to unlatch the door, but keep it as closed as possible, also watch your cedar shims).
6. Do more Play-Doh tests. Re-roll your Play-Doh and repeat until you've split the difference.
Hinge Side Play-Doh test after adjustment:
Latch-side Play-Doh test after adjustment:
![Fixing Blaze King Ashford 30 door stink with Play-Doh Fixing Blaze King Ashford 30 door stink with Play-Doh](https://www.hearth.com/talk/data/attachments/264/264185-aef718885960501436ee17d93002a10b.jpg)
7. Test the latch. If you move the front panel to far left the latch will drag, which sucks. You could probably pull out a file knock down the latch-grabber-arm-thing on the edge, or you can slide the front back a touch and go for "best fit".
8. Test vertical gasket grooves with more Play-Doh, this is your chance to make it perfect.
9. Tighten the 4 front panel bolts (caution, do not over-tighten, maybe snug plus a half turn, the BK bolts would probably turn until something broke).
Tightening the front with one extra spacer:
![Fixing Blaze King Ashford 30 door stink with Play-Doh Fixing Blaze King Ashford 30 door stink with Play-Doh](https://www.hearth.com/talk/data/attachments/264/264186-55bb26d1f4aedf52131dc7a332eecd19.jpg)
10. Install a new gasket, get your red RTV ready:
![Fixing Blaze King Ashford 30 door stink with Play-Doh Fixing Blaze King Ashford 30 door stink with Play-Doh](https://www.hearth.com/talk/data/attachments/264/264187-a0c8b55ca38acec5d9bc1778daca2b58.jpg)
11. Enjoy a nice fire free of the smell of beef-jerky.
![Fixing Blaze King Ashford 30 door stink with Play-Doh Fixing Blaze King Ashford 30 door stink with Play-Doh](https://www.hearth.com/talk/data/attachments/264/264188-5a6df706fe4e593b46804b2d52a4b32e.jpg)
Loosen these:
