Fix sagging wood stove door?
bonniejay
2
USA
Hi, how can I fix sagging door on QuadraFire Millennium 3100 wood stove? Handle has been adjusted multiple times but the whole door sags a bit on the hinges and does not seal at the top corner. Thanks for any suggestions
Can a thin washer be used on the lower hinge pin to raise the opposite corner?
Reactions: Wisco Shepherd
Quad doors have two hinge pins to hold door on if I remember correctly. If those pins wear or the hinge assembly on the stove is worn, it can cause a door not to fit properly. A washer may help the situation, or may not. Good luck with that.
