The stoves with angle iron on the corners that becomes the legs at bottom were not UL Listed. They had no shields. Stoves with rounded bent front corners should have a shield on the back with tag affixed to the shield on this model.
Price should be much higher if Listed, which can be legally installed in areas that do not require EPA emission certification. Without the tag, it is now unlisted, even if there was one originally. Codes now require all appliances to be Listed with Label affixed in most states and Canada.
Feet vary in price. There are 2 types with many variations. The first type was the forward facing type like yours made of cast iron. You would have to verify that with a magnet first. A magnet should stick to yours. In this design there were first chrome plated smooth, and chrome plated with Fisher Stoves across toes, (both of these with or without holes in the bottom) and the last forged from cast iron had hair detail, which I believe yours is, not a smooth finish. This last style was available in plated brass, or black oxide finish. When the plated version gets rusty, people tend to wire wheel the rust off and paint them black. They look like the iron oxide finish, but are not. So I have not taken the chance buying a set online since I have all the others and only need the original black oxide finish set. This is why I asked if you, being the original owner painted them, or if they are the original finish. This is similar to bluing of a gun barrel with controlled corrosion preventing oxygen from getting to the clean metal under the coating preventing rust.
The second type are angled, not facing straight forward. Non-magnetic with engraved hair and white brass plating. They are marked inside on bottom FISHER INT EUGENE OREGON. The cast iron type has no identifying markings.
Without a UL Label, you should get as much for the feet or more than the stove only. Stove prices vary by season and location. An area that requires inspections can be worthless unless finding someone willing to install illegally, as well as being unlawful to sell in some jurisdictions.
There is a sub-forum here for classified item sales. Let me know in a PM if you list them here or elsewhere.
