I have had the stove for 15 years and it didn't have a baffle when I got it. FYI- There is no name plate on the stove. I have identified it by some posted info. here as the Papa Bear and other than the door having Fisher on it there are no other markings.
While replacing the fire brick I noticed two 1.5" angle iron clips on each side, just above the side fire brick, about 2/3 the way back as shown in the pictures. I'm pretty sure they are for a baffle. They are just wide enough for a fire brick too, which has me puzzled.
The manuals I found online don't show this model in detail to show the baffle. I have found some similar but I wanted to see what was OEM. It appears that the Mama Bear would be similar.
Does anyone have pictures, a diagram etc. showing the OEM baffle assembly that they could post here or send me?
Are there any home-brew improvements to the baffle assembly that I could make?
Are 'secondary air tubes' something worthwhile to fabricate/use on this stove?
Thanks.
![shade smirk >> >>](/talk/styles/default/xenforo/smileys/shade_smirk.gif)
Thanks.
