fisher grandma bear
grandma bear stove
2
wi
I have a grandma bear stove. The smoke baffle has burned through and I want to remove it to replace it. Is there an easy way to remove the old one? I would like to replace it with the fire brick shelf so it would be easy to repair and maintain.
A 5/16 thick Smoke Shelf Baffle in a Series III burned through???
Did it look like this one?
fisher grandma bear
Mine slides right out, but it's not warped or damaged in any way.
I've seen them warp and beat flat, but never burned through.
yes the baffle had warped with a hump under the flue pipe last year and now has burned through. It has a hole about 3" across. I've set a fire brick over it
i believe mine is a grandma bear, and noticed the exact same thing with mine.Im goind to put in 1/4 stainless.
