In some cases, you're correct. As you stated a lot of stove manufacturers advertise a BTU rating based on input BTU - how much fuel you put in. However, not all manufacturers do this, and that's why you need to check the manual for specifics. In the case of the Harman P61a the manual clearly states a BTU
output of 61,000 (hr). No efficiency or feed ratings are stated there, so you have to make an intelligent guess at one to get to the other. It's confusing because on a few places on their website the list the same stove with an
input rating of 61,000 BTU. I had to make a choice, but in my opinion it's much more likely that the manual is correct and the website is wrong - they even have a disclaimer on the specs page of the website to refer to the owners manual for complete specifications. My PAH is the same way, it's advertised by its output rating, 25,000 BTUs. Fortunately, my manual also has listed the feed rates, and efficiency - and shockingly enough all the numbers match up like they should.
At any rate, like I said before, if you're getting 61,000BTUs out you need to put in 82,000BTUs at 75% efficient - 10lbs/hr. Really, if the owner chimes in an lets us know how many bags a day he goes through a full day of wide open running, we could confirm/deny some of this. I really have to question the 85% efficiency number too - I'm sure if Harman was able to get that kind of performance out of their stove they would be praising that number all over the place. In my stove research I did when shopping I found a lot of manufacturers don't post their efficiency. The one's that do are usually the strong performers with regards to efficiency and usually around the 75-80% range. I gave Harman the benefit of the doubt in my calculation and gave a pretty good number - I don't recall seeing many stoves at all above the 80% mark when I was actively shopping - and those that were rated about 80% were highly touted as being such.
You got my 100% agreement there - heat cycles are what kills stuff in general, not operating temp (as long as the device in question does not exceed a maximum operational temperature.) We'll see in a few years if the door still shuts tight on my stove!
![Wink ;) ;)](/talk/styles/default/xenforo/smileys/wink.gif)
White haze indicates a clean hot burn, and a nicely tuned stove!
