It's far south. Would be warmer at night, but for the high altitude. We went from cool nights in Oaxaca then west down to the coast at Puerto Angel and the difference was very noticeable. We celebrated New Years there and wined and dined outdoors every night. Even at midnight it was comfortable to be in a short sleeve shirt.But 78 during the day! That really is quite a swing.
Where would the pellets come from?I havent read thru the entirety of the post but you might be happier with a pellet stove as u can turn it on and have good heat in a few minutes and turn it off and have zero heat within 15 minutes or so
Yes, some heat will be lost, but this is not 20º weather outside. Last Nov. we stayed in Columbia at an even higher altitude in a home with no heat other than a fireplace. There was plenty of glass and night time temps in the mid 40's. It was cooler in the morning, but not miserable. With large patio doors the sun did a good job of warming the house. We only had a chill chaser fire one night. The thermal mass of the home made the difference.Im not sure adding windows is going to help relieve night time temp drops. Any radiant heat from the added windows would quickly dissappear once the sun went down. Glad they are coming up with healthier alternatives for cooking cause breathing in all that smoke is horrible.
It gets hot on the coast. In the valley, inland high plateau, it's cool in the shade, never hot at night, but it can really scorch under the sunIt's far south. Would be warmer at night, but for the high altitude. We went from cool nights in Oaxaca then west down to the coast at Puerto Angel and the difference was very noticeable. We celebrated New Years there and wined and dined outdoors every night. Even at midnight it was comfortable to be in a short sleeve shirt.
Too much heat lost at night through windows. All solar gain lost rather quickly. If I were building a house I'd use solar and pump hot water under slab. But for what I got, I'm thinking a stove will do me rightStill disagree with the window theory for the particular situation unless used in conjunction with a heat source other than solar radiant. Propane on the other hand would be ideal assuming a tank gasline and fuel are not an issue.
If the budget allows ive had good luck with ventis but theres plenty of other good options out there. 6" Appliance connector, Double wall connector pipe if budget allows Flat ceiling or cathedral? Flat go with 11" ceiling support box catherdral go with 24" ceiling support box. i would save money and not get truss spanners and frame around the box with 2*4s. You can get trim for the support box if you choose. The ceiling support boxes should come with an adaptor to go from connector pipe to class a chimney pipe. Class a pipe 304 should be sufficient. You want to go from the ceiling support box till the chimney ends with the class a pipe. Ceiling support box should extend into the room with the connector pipe at least 6". If in a attic recomend using attic insulation sheild. Ive only delt with metal and shingled roofs cut your hole run the pipe thru maintaining clearances put your roof flashing on storm collar and rain cap i like to use roof braces as well especislly if the chimney comes out of the roof more than 5 ft or in particularly windy areas. This is the basic version will need more information or pictures to give an actual pipe and parts breakdown as well as step by step instructions.
This would be a very basic example.
Looks like my attempt at sending photos failed. Will try again later![]()
https://newhaven.craigslist.org/for/d/stainless-stove-pipe-wood/6606130573.html
12' piece triple wall... is buying used a bad idea?
https://jerseyshore.craigslist.org/for/d/wood-stove-out-pipe/6617244974.htmlLooks like my attempt at sending photos failed. Will try again later
The T19 is the predecessor and a fine value stove.Thank you folks. I have a better picture of size and pricing. Mr begreen: Is T19 comparable to T20? If so, I may be close to a purchase.
Next I'll have to bother you folk some more for info on what type stove pipe to buy and how to install piping/assembly.
