I put temp probes in. That one, the plumber forgot. He left me a spot for it. I bought a combo pressure/temp. Pressure reads about 2psi below output.. Makes sense.. it's literally 6" before the pump on boiler input.
I have temp probes on each side of wood boiler. Top of both tanks, and on both legs of injection loop. I wanted to KNOW what was going on.
Boiler dealer is the one that sold me the return protection. I'm trying to see what the issue is. It seems my pump starts at a much lower temp than many of you, and my return water temp is lower.
However.. I'm trying to realize why this is an issue. It's not as if I have a huge delta T in the boiler. When I started it.. The storage water was 53! So, boiler heated up the water inside itself to some number. I can't remember, but let's say it was 100. Then the circ came on. Water in the boiler just went around and around because the return water protection was fully closed.
As the boiler heated up.. it started letting a little bit of that hot water go out to storage, and mixed in just a little bit of that 53 degree water from storage. Return water did not waiver off 120 ever. Boiler kept slowly warming storage till the return water got to 120.. then it climbed above and heated the tanks up to 190 or so.
I think the biggest delta T I ever saw on in/out of boiler I saw was around 25. Most of the time it was 15 or so degrees. So, what's the issue?
I'm not discounting anyone's knowledge, but realize that I do not have the same boiler as you do. I can't understand WHY what is going on with my boiler is an issue. I have a few issues with my boiler... but I think that's more to do with me learning how to fire it, and wood seasoning. I never had big creosote, but I could see a thin black shiny film on upper firebox. A few of the pieces I threw in were for sure wet and heavy. Most of what I threw in was dead and plenty dry.
The learning curve is steep. Be patient with me. I'm gonna ask the dealer a few questions when I get a chance.
JP
I'm at a loss. I certainly do want all the input. I'm just not sure at this point. The dealer said that the thermic valve is 140 degrees. I saw 120, rock solid, during the entire operation until return from storage water was above that value.
Bad valve? Improper install?
I've only had ONE cold start.. so I can't say with any certainty at what point the circulator starts. I'm learning as I go. I'm sure all of you remember that the learning curve is very steep at the start.
I installed many manual temp gauges for just this issue. I want to know what is going where. I just need more burn time to figure it out.
Fred.. it's not a danfoss brand. the ports do not line up like one. That one caused me several emails and phone calls to confirm correct orientation. I'm confident the pipes are connected as I was told. HOWEVER... it seems to me to maintain a perfect 120, not 140 as everyone says.
JP
I'm leaning towards bad valve. Otherwise.. there was NO temp rise going thru the boiler. It was routinely 15 to 20 going thru the boiler. Pressure difference was 2psi. As I said, one was literally 6" before pump input... so that makes sense.heads or tails
Leaning towards bad thermometer at that point. Boiler doesn't creosote up.. and I really plan for a fire when tank bottom temp is 140 anyway.Did you ever figure out what your problem was? bad mixing valve?
