Tanks aren't insulated.. so I won't go too nuts with it right now. Just watching everything happen.. slowly.Congrats!! Never thought that you'd ever be wishing for a little longer winter did ya!
Half a firebox only according to the dealer.
It's starting to hum along nice now. Flue temps up into the low 200s. Boiler output is 143 and input rock solid at 120. it's sucking that 53 degree water out of the storage bottoms and mixing it well. Storage top up to about 62 now.
No leaks.
Think I'm done for the night. I'll let it go and see how it does on shutdown. I've got it set to shutdown at flue temp of 160.
Very happy with it.
JP
I used scrounged 500s. Vertical.Nice. I'm a little ways off from getting mine installed. Still waiting for the quote that didn't come today. What kind of storage tanks are you using and where did you get them?
Neil
pressure doesn't now which way is up.Congrats JP. I have the same expansion tanks and I think I recall that they should be installed vertically.
Huff
And unfortunately neither did John-John Jr, apparently.pressure doesn't now which way is up.
Do not hang models SX-30V through SX-160V. They are ... standing
models only.
I would assume that they mean don't "hang" them like you would hang a small tank.
WARNING: Mount vertically only. Do not mount on dead-end pipe.
2. The EXTROL must not be placed overhead ... EXTROL should be relocated per Figure 1.
Figure 1.
3. Do not place the EXTROL on a dead-end pipe. Air can collect in the
EXTROL, causing internal corrosion and possible leakage.
I would assume that they mean don't "hang" them like you would hang a small tank. They are not meant to hang from their plumbing connections like a small tank.
JP
Got ya. I'm going to move them to the floor. Everything works.. quite happy with that. Seems like it would take a LOT of wood to get that last 10 degrees from storage to 195 from 185. Maybe it would be easier if tanks and pipe were insulated.The thing is, when the system gets hot, the expansion tank takes up water from storage as pressures rise.
The expansion tank also should be able to return that water to storage as temps & pressures fall - if they are horizontal that is less likely to happen. Very hard to get all the water out when it is below the inlet.
The draft fan on my biomass wont pull all the smoke out at a full burn either. I was allso wondering about the circulator turning on at such a low temp. Your circulator shouldn't turn on to at least 150 F minimum. I have mine set to come on at 172 I believe.Retun water protection is working. About 115 or 120 it started letting heat out to tanks. Right now return water about 110, out of boiler is 120.
Flue temp is 150s and climbing. Had to set my min temp back. It thought I was out of wood.
Pretty happy with it so far. Draft fan isn't strong enough to keep all the smoke out. Need to learn to leave it alone and not peek! Who'm I kidding.
JP
I had much better luck with the draft fan by waiting 30 seconds or so.... then crack the door and wait a few seconds. Way less smoke that way.The draft fan on my biomass wont pull all the smoke out at a full burn either. I was allso wondering about the circulator turning on at such a low temp. Your circulator shouldn't turn on to at least 150 F minimum. I have mine set to come on at 172 I believe.
