Have to say I am impressed with the New Yorker, more on the coal side than the wood side, but either heats well. Difference is obvious in smoke, soot, and burn time. Been within 5 to 10 degrees either side of zero for about 48 hours now. The New Yorker WC90 keeps up, but will go through a load of wood in about three to four hours without some "help".
"Help" lives in the living room and is purring at 650 degrees, heating the entire 1,800 sq ft first floor apartment to 75-80 degrees at various points. Burn time is up to 5 hours now in the WC90.
Changing over to coal this evening, as I have to work tomorrow and want it "tuned in" before I load to leave for work. Near as I can tell, it requires the maximum 1/2 inch at the air shutter on wood, and about 1/4 inch on coal. When I leave in the morning, I'll turn the heat down to 50 degrees in my apartment to keep demand low, and stretch my coal burn as far as I can, given the really cold conditions outside.
Side note... definitely not something I'd recommend to anyone else. Old timer told me to prop the cleanout door open and break the draft. "Same thing as a barometric damper", he says... not exactly. If you "KNOW" your chimney is clean, and the thing is pulling a draft out of a horror show, it's likely not a "problem". If you were to have a chimney fire, molten creosote and fire would run out onto the floor and you'd be out of a house. So far as anything "backing up" like carbon monoxide, dioxide, or smoke... no possibility.
When I inspected it the other day, as I put the mirror in and got it sighted, I could see little bits of whatnot being sucked up and out of the chimney... going to get barometric damper installed as soon as I can get one. Also replacing the galvanized oil burner pipe with solid piping... with barometric damper installed and getting a draft meter to build in...
I like the way the boiler acts with less draft. Cleaner fire, higher stack temperatures coming off the boiler, and it comes up to temperature and idles much better.
Lucky I've got that... New Yorker says, 15 foot tall, 8x8 masonry, or "equivalent".
