I had a BK Princess 32 installed last fall. I've run it 24/7 since it got cold enough. I noticed in the last couple of weeks the smoke spillage had increased during reloads and then one day if was really bad. I climbed up on the roof and found my raincap half plugged with flaky bubbly creosote deposits, whick i cleaned out. I also recall hearing what sounded like ice pellets from up high in the chimney occasionally, maybe 10 times or so in the last 6 weeks. I bought a Sooteater and cleaned out my flue for the first time last night. I am curious what you guys see? The pipe didn't look too bad to my novice eyes and cleaned up easy enough, but the end of the pipe and cap has some buildup. Was that sleet sound crap burning off my cap maybe?
TIA,
Dan
![First chimney sweep First chimney sweep](https://www.hearth.com/talk/data/attachments/309/309675-550812f0ce3dd2f3ae8644913db6157f.jpg)
TIA,
Dan
![First chimney sweep First chimney sweep](https://www.hearth.com/talk/data/attachments/309/309669-bc3a0ebb608a067ea281ceb53c565d5a.jpg)
![First chimney sweep First chimney sweep](https://www.hearth.com/talk/data/attachments/309/309671-d8bdeadfc628b68521c52cada5d7d887.jpg)
![First chimney sweep First chimney sweep](https://www.hearth.com/talk/data/attachments/309/309672-c20c8b63a4da59ccbaac1e08e1566771.jpg)
![First chimney sweep First chimney sweep](https://www.hearth.com/talk/data/attachments/309/309674-b09d16679d77b3b9f39615b8da916678.jpg)
