Regular Maintenance - 2 Week Run
I usually clean out the fire box every weekend. But this time I let it go two weeks maybe
three or about 14 bags. Note: I have not been in the igniter area for about a month.
![[Hearth.com] First 1 Ton Cleaning - XXV [Hearth.com] First 1 Ton Cleaning - XXV](https://www.hearth.com/talk/data/attachments/90/90150-8fb425a58d665179ba2d9f1106e631ef.jpg?hash=-3vdvFL7xA)
 ![[Hearth.com] First 1 Ton Cleaning - XXV [Hearth.com] First 1 Ton Cleaning - XXV](https://www.hearth.com/talk/data/attachments/90/90151-6a0a64454fe351266e4a6ff83dc2d4a2.jpg?hash=vSMq00qMoD)
Here is what the burn pot looked like after a few days with no attention.
![[Hearth.com] First 1 Ton Cleaning - XXV [Hearth.com] First 1 Ton Cleaning - XXV](https://www.hearth.com/talk/data/attachments/90/90152-18f99be1a3cfbb3aa4a9ed3dde436b16.jpg?hash=64RyMKOkiy)
I used the 17" pry bar to remove the bulk followed by the small flat screwdriver
to clean carbon from the auger, auger tube and flat area around the tube. Since
I was going for a deep clean I finished off the burn pot with Scotch Brite.
![[Hearth.com] First 1 Ton Cleaning - XXV [Hearth.com] First 1 Ton Cleaning - XXV](https://www.hearth.com/talk/data/attachments/90/90153-159b1a52c706398f23754a728afa1599.jpg?hash=bCe4KJoZiU)
I keep a 90 deg pick handy for the air holes but they were fine.
![[Hearth.com] First 1 Ton Cleaning - XXV [Hearth.com] First 1 Ton Cleaning - XXV](https://www.hearth.com/talk/data/attachments/90/90158-eb69b1ca732bd4e9f8374e041efb4f63.jpg?hash=YDiiQWM7rW)
On to the igniter area. I tapped on the top of the burn pot to knock loose ash off the igniter.
Then went under for the clean up. I used a small hose connected to the vacuum to get way
down in there.
![[Hearth.com] First 1 Ton Cleaning - XXV [Hearth.com] First 1 Ton Cleaning - XXV](https://www.hearth.com/talk/data/attachments/90/90154-cf2a5ffa4604ed5de52ebfe2a1860a23.jpg?hash=vQQ3fiptqM)
 ![[Hearth.com] First 1 Ton Cleaning - XXV [Hearth.com] First 1 Ton Cleaning - XXV](https://www.hearth.com/talk/data/attachments/90/90155-f8b5618859e780bfbaba6d6dde612a6c.jpg?hash=wxjfIBXeDI)
Below shows the fire box clean. Flame guide wire brushed and the heat exchanger
cleaned with the 2" paint brush. Followed up on the exchanger with the Scotch Brite.
![[Hearth.com] First 1 Ton Cleaning - XXV [Hearth.com] First 1 Ton Cleaning - XXV](https://www.hearth.com/talk/data/attachments/90/90157-02736e8a36154ffa20bea9d18872d609.jpg?hash=Z1ISddS_JT)
 ![[Hearth.com] First 1 Ton Cleaning - XXV [Hearth.com] First 1 Ton Cleaning - XXV](https://www.hearth.com/talk/data/attachments/90/90156-e7cfab311ddfcf7518adf5375f0fe600.jpg?hash=QsBtt4R539)
Well, that about wraps it up. I was really curious to see what the inside of
the stove and venting would look like after 1 ton. Not to bad IMO. I think the XXV
is doing well.
I would have liked to get more pictures of "doing things" like a "how to" but I was a bit
short on time and taking pictures of all this really slows down the progress.
I will flesh things out next round when I do..."A Ton of Cleaning".
![[Hearth.com] First 1 Ton Cleaning - XXV [Hearth.com] First 1 Ton Cleaning - XXV](https://www.hearth.com/talk/data/attachments/90/90159-ec2e4de93b342d9242d82c8646028cbb.jpg?hash=yC9pgF3kf7)
down in there.
is doing well.
