wood1 said:the wood is seasoned one year i have it at 1 know for about a hour and still 425.
the splits are small to medium i bought this wood, after about a hour the fire is going pretty well good flames so thats why i try to turn it down and thinking maybe the hot coals and smoke will really get that cat going, but that doesnt seem to work for meTodd said:How big are the splits and how many are in the fire box? Did you buy this wood or process it yourself? What does the fire look like at #1 after an hour?
i bought the wood cut to 16" and split its maple and oak i brought it inside my basement and stacked in there it has been in there for about two weeks and no i don't have a liner its a inside chimney that is a 6x11 rectangular clay lined chimney, i believe i have sufficient draft before i started it this season i took a match and follwed what woodstock said to check draft and it went towards the chimney. also i dont get puff back.fire_man said:wood1 said:the wood is seasoned one year i have it at 1 know for about a hour and still 425.
Was your wood covered really well for at least a couple months before you started burning? Last year I had trouble getting the Fireview up to temp with 1 year seasoned wood that was poorly covered and got wet under the bark. This year I made sure to cover it better and what a difference! Also, is your flue lined with a 6 inch SS liner all the way to the top? This stove (since it has a cat) needs a really good draft to make up for low stack temps.
true i got the stove in the fall and scrambled for wood..LLigetfa said:That doesn't mean it's dry.wood1 said:the wood is seasoned one year ...
it sizzles a little but doesn't foam. how much would the liner help? the wood was in log length then cut and split, i don't believe he had it stacked.He said it was one year seasoned.. so i next time i will have to start to season my own wood or try to find someone who truly has "seasoned" wood.Todd said:I'm willing to bet the wood isn't dry. Does it sizzle shortly after reload? Most firewood dealers don't sell wood that has been cut, split and stacked for at least 1 year. Many here have been in the same boat as you the first year and have to deal with what they got. If your wood is suspect you can compensate by loading the stove more loosely, not tightly packed, burning in the bypass mode a little longer and burn with a little more air after engaging. You might have to burn your stove between #1 and #2. You should also look into a reline for that 6x11 chimney for best results.
wood1 said:it sizzles a little but doesn't foam. how much would the liner help?
wood1 said:thank you all for the help, i thought i had some good wood, but i know now it's not optimal wood, but will burn.
so i will start buying green or seasoned wood and stack it outside and hopefully that will get me ahead of the game for next year.
all this time i thought i was doing something wrong. again thank you all and hope you all had a good Christmas and have a happy new year. Update on issues.......... I have the air set at 1.5 and this thing is cruising its at 575 and slowly going up. Its heating nicely, know if only i could get to do this all the time. Maybe next year.. thanks guys
fire_man said:wood1 said:thank you all for the help, i thought i had some good wood, but i know now it's not optimal wood, but will burn.
Also try splitting your semi-seasoned wood smaller - like 3" or 4" Max width. I know it's a pain, but maybe you could try it with one or two loads just to see if you can then run the stove at an air setting of 0.5 and get the higher cruising temps.
wood1 said:i have a question i go to work at 6:30 am and load it before that then get home at 6 or 7 then reload a few pieces and the again at 9 or maybe 10 if i can stay awake that long. with this schedule in your opinion is this going to realistically heat the house or is it just a waste of time? not to get off track or take over the thread.. not sure where else to post such a question?
