Hello - I've seen one other post on this forum about this furnace. I've have it for many years and it has worked great until a couple of weeks ago. The main blower stopped working (just a humming sound). I suspected the motor was binding. I unwired the two wire main blower to remove it from the housing. It did not turn easily so I knew it needed lubricated. I did that and got it working/turning freely again. But after re-installing and re-wiring, the main blower doesn't turn on when the furnace gets up to temp.
It has a Honeywell 4 terminal fan limiter (pic attached), Honeywell R8285A Control unit (pic taken from top attached) and a second transformer (pic attached).
The R8285A controls a 120V damper blower in front of the furnace and it works ok; I turn up the thermostat and that turns the damper blower on. The main blower's two wires are connected to the 120v source power black and the other was originally connected to the white wire coming back from the limited and a white neutral wire that goes to the second transformer.
The transformer pic shows the black and white wires and a small blue wire that is jumped back to the top of the control unit. If I test the black and white wires on the transformer before the furnace is gets to operating temp, I read about 34V. Then when the furnace gets to operating temp based on the limiter setting, I get almost 0v on those two wires. I'm not sure what the purpose of the small small blue wire jumped back to the control unit does.
As an interim fix, I have the main blower wired to a separate power line, so that I can turn off and on with a switch right inside the basement door. So now the main blower is either always on or always off based on that switch (no fun) and I am stumped on why when originally rewired. the main blower does not turn and off anymore.
If anyone has seen a wiring setup like this (perhaps the guy who posted on this same model back in 19' knows) and has any ideas, that'd be great to know!
![Firepower 2230 Add On furnace - wiring diagragm Firepower 2230 Add On furnace - wiring diagragm](https://www.hearth.com/talk/data/attachments/269/269884-b531497d3224d3023f67be12a1fae1f3.jpg)
![Firepower 2230 Add On furnace - wiring diagragm Firepower 2230 Add On furnace - wiring diagragm](https://www.hearth.com/talk/data/attachments/269/269882-70272bc94fa6cd19b495cad1732ba5d5.jpg)
![Firepower 2230 Add On furnace - wiring diagragm Firepower 2230 Add On furnace - wiring diagragm](https://www.hearth.com/talk/data/attachments/269/269883-272939130b14249f845d398efa7a455f.jpg)
