Hi all,
I'm a new FPX (Lopi) large flush insert owner and wanted to weigh in / ask a few questions here.
My impressions so far:
- It's a good looking unit. Clean lines, minimal.
- It's easy to get up to temp from start. I've followed Travis' recommendations to get a smaller, intense burn going before adding.
- Even with the air wash and running good burns without much smoke, the glass does get dirty. Fortunately, it's been relatively easy to clean with glass cleaner and water/ash, but I'd rather not have to do this every time! Any recommendations here?
- My main issue so far is that the blower doesn't kick on for a long time. Often it takes 30-40 mins and cat temp is 800-900 degrees before it starts up. Seems like a bad spot to put the snapdisk (lower right). Anyway, the store recommends trying to bend the disk closer to the unit, so it heats up faster. I plan to do this, but need to figure out how to disassemble the front to get access. I'll check the manual, but appreciate any directions here.
- The blower fan, which is loud itself, often creates rattles in the lower vent. I'm guessing there's not much you can do about this, but am open to suggestions.
Thanks in advance for any help!
