altmartion
sorry, I didn't see that in there.Electric boiler = central heat.
Trust me, we are. In addition to the usual household of computers and half dozen television sets, we have four AC systems (15 - 16 tons combined), three dehumidifiers, more than 200 incandescent lights (most of which my wife leaves on continuously), two electric water heaters (in addition to the one on the boiler), five refrigerators, one freezer chest, and a shop full of machines lugging 3 - 5 HP motors (16" radial saw, 14" table saw, 18" & 32" band saw, 6" and 16" jointers, 3hp heavy duty planer, etc.). Every time one of the AC units kicks on, every light on the property dims to 1/2 intensity. With 6 sub-panels, panel space is actually not one of my issues.I doubt your pushing the limits of your 200amp service your probably pushing the limits of your panel which may need a sub panel unless your operating multiple electric stoves. Electric hot water heaters typically are 4500w or 5500w ( 30 amps ) same as a HPWH. You have to size for worst case which is pure electric.
I do think we have a main feed problem, but haven't had time to deal with it. I don't think the inrush of a 5 ton AC unit should be sufficient to cause a significant drop in mains voltage, but that's a separate issue from net capacity.
Insulation is a project we'll be tackling this winter, along with rebuilding and re-storming a half dozen windows each summer. I'm curious, what was your outlay for the HPWH? What size circuit does it require? We're really pushing the limits on our 200A service, and aren't entirely unhappy to continue running oil for DHW, as I figure it's not the worst thing in the world to keep the boiler in running shape with a little exercise.
Didn't really mean to derail the OP's thread, but heating is wood + oil, for 96% of the house. We have a heat pump (mini-split) which heats only 260 sq.ft., and electric resistive in three of the bathrooms, but that's pretty minimal compared to the summer AC load. The AC tonnage is based on cooling 6660 sq.ft. of house plus 1200 sq.ft. of shop, so 7860 sq.ft. total. In fact, the shop is not even up and running yet, but I have it planned into our service loading, nonetheless.Heating and Cooling load are not added together in a load calculation. Presumably you do not run both at the same time.
Thanks for the info! At 10 months usage per year, and with the need to keep secondary options, I don't see the HPWH working out for me. The issue is as much about time, effort, and space, as cost. We're in the thick of so many projects, expansion, renovation... but it's an interesting option to consider.I paid circa $900 for a Geyser HPWH from Tom in Maine (http://www.americansolartechnics.com)
There is a thread showing pictures of my installation: https://www.hearth.com/talk/threads/ducting-and-geyser.108580
The Geyser uses a 15 amp supply. My KillAWatt meter shows that it rarely draws above 12 amps.
We still have our original 80 gall oil HWH and keep it operational for those weeks in Jan/Feb when the Geyser struggles. Our Geyser is in a fully "in bedrock" basement and this stays above 50 degF year round so we can use a HPWH for 10+ month/year.
Our house is 1800's Federal, National Historic Register, so we have some limits on what we can do. The insulation & sealing process took place over 3 years. Did a lot of infra red work to set the job list for the year. Repeated at annual intervals until we started reaching diminishing returns.
We basically reduced our overall energy consumption and replaced our oil heating with pellets and chord wood.
We have kept the oil systems fully functional for use during vacations etc. but they are not used on a daily basis.
