Thanks guys to hopefully catch up on some questions we are looking at 20-25’ total pipe straight, basement install. Pipe inside except exposed chimney. This would be a larger around 3+ cubic foot non catalytic stove, if our other heat sources have to back us up a bit that’s ok, and I would rather keep the stove within range than push things past their limit if that makes sense.
That 1400-1500F range seems to be around the lowest of temps it sounds like it’s best to not exceed for some of the internal components and now I am also just frankly curious on firebox temps at this point.
Most manuals just say keep it from glowing, sounds like that’s about 850F outside so I am wondering if you stay below 850F if we’re below that 1400-1500F range in the firebox. But sounding like I would want to keep stove top temps quite a bit lower than that from what I’ve read, 700F or less sounds ideal for most stoves from what I’ve read on here so far.
Obviously sounding like the first thing I’ll be getting after install is an infrared thermometer that goes that high but I am curious if anyone else has measured their firebox temps and possibly in relation to their stove top temperature. Thanks for the input.
