Well if that don't make ya crazy, this should!![]()
https://www.hearth.com/talk/threads/firechief-1700.164366/page-2#post-2327605
Yea I am all over that one also.
Calling all experts, looking for feedback besides the stove is junk.
Think anyone following this thread knows I am seeing high flue temps. What have also noticed is while I am seeing high flue temps the upper front of the stove remains at much lower temps until at least an hour after loading. I would assume that the heat from the fire would have to travel from the back of the stove to the front and into that area above the fire box. I would assume the result would be a balance between the flue temp and the front of the stove, but that is not the case.
Here is a photo of where you can clearly see the secondary burn is only at the far rear of the stove.
I am assuming the secondary burn is only at the rear of the stove because the front of the stove is not hot enough to achieve a secondary burn. However that heat is somehow making its way to the flue?
Just something seems off (please no stove jokes). So you guys have worked with stoves long enough to be able to troubleshoot. Any thoughts to the high flue temps and low temps front of the stove?
I did check to make sure the brick was pushed all the way back.
feeding you horse chit by the buckets
Most stoves get their air from the front, and burn from the front...this one gets its air from the back, no?
Plus you can't really tell what happens in there with the door closed...the split second you open the door things change...
Not trying to be a buzzkill here, but there has been alot of advice and much of it is being repeated. Are you come to us for advice or your buddies over at HYC who are feeding you horse chit by the buckets?
Black mark means cold dirty burn...the lighter the color the hotter and cleaner the fire is there.that black marking tells me the heat is concentrated in that area.
Primary air openings supplied in the front, just below the front door opening.
Secondary air is supplied via the rear of the stove.
I have had a lot of calls/email exchanges with HY-C, mostly providing data on a 10 hour and 4 hour burn time test. They have not come back with any suggestions, just trying to capture data so they can compare (I think).
I am turning to the folks of this forum as several here have had different stoves, each with different issues. Most, if not all suggestions, have been tried and results reported back to the person that provided the suggestion.
Trying to focus in on the high flue temps, no matter the draft. Just seems odd that flue has crazy high temps where the front of the stove is cooler (smoke shield removed).
Simply can’t swing 4K on another stove right now.
I guess you have somthing to work with now...
A manual flue damper costs $8... no one is telling you to go out and spend 4k on a new stove. Most of us are just asking you to address the elephant in the room (flue draft).
If you put a simple damper in today and get back to me saying your flue is now 400-450f I'd call that a success. (Use your Dwyer to help calibrate your draft, simple simple!).
From there you can rig a tempurature controller with a timer for load and go startups using your blower fan. Once the fire is established the blower wont turn on until you reload.
Obviously their are limitations to your stove but let's give it a fair shot... try the suggestions, it's not going to break your bank.
What if adding a damper & getting the draft in spec, kills the secondary burn & starts making creosote?
And another $100 gets you semi automated with the aftermarket temp and speed control hack that has been proven to work oh so well on these things! (and others)Oh, by the way, the Tundra II is only $2500...and less if you catch a sale.
https://myfireplaceproducts.com/us_en/drolet-tundra-ii-wood-furnace-df02001 free shipping too
From the furnace manual itself...View attachment 238402
I guess that statement is a requirement by some agency, if you want to sell a wood stove.
One other thing to remember, firecheifs have overall lower efficiencies than just about all those listed in the EPA list. That also translates in higher flue temps.
The idea isn't to kill the draft completely, just to slow it down to the manufacturers specification. Visual check of the chimney before and after damper will help determine if more draft is needed for combustion.
That's kinda like saying you will get creosote if you have a 16ft chimney opposed to 28ft. You shouldn't need 0.1- 0.2 draft to get a clean burn that unrealistic.
Exactly...somewhere in the past the link to the EPA test on this thing was put up...this thread or one of the others like it on FC problems...the burn times were short.So, when they tested they probably passed with very high flue temps and short burn times
Let me ask you a serious question @Mrpelletburner , when you were looking to buy a wood furnace, what all models did you seriously consider?
What was the deciding factor that made you pick the FC1000?
I wanted blue, but couldn't find a reasonably priced high temp blue that I liked...so yup, red it isred, he liked the color red..........like someone else I know.![]()
