Medic21
I think its for sale![]()
Do you deliver lol
For the right price.Do you deliver lol
License get revoked?LOL
boo boo bus
never heard that one beforeHauling corn?to the semi in the morning.
Hauling corn?
Yeah we have had rain every few days for the last month, they are using 4x4 tractors with duals the whole way around and pulling dump carts to get the corn out to the trucks on the road due to the mudCorn and soy beans. We had just gotten harvest started and got hit with 3 inches of rain friday
Took me a minute to get what boo boo bus meant. That is pretty good.Harvest time would be the best time for that to happen lol. Unfortunately no, I get to go from a 14hr shift on the boo boo bus to the semi in the morning.
Not much brainstorming needed...just need to walk down the hall to engineering, pull the page out of their book that has the FC1000 primary/secondary air system design on it, feed it to the engineer that came up with it, then fire him/her, find the next engineer in line and tell them to do better (which should be pretty easy to do)they flew out to my house to double check the setup and go back to the lab to brainstorm.
That looks like water vapour. Most prevalent after loading. The more there is, the more moisture in the wood.
That looks like water vapor. Most prevalent after loading. The more there is, the more moisture in the wood.
Couple updates...
Have the draft flapper adjusted a just past the riveted spot. I have the non opened end tapped to cut down on the air opening. If you own the stove, you should know what I am talking about.
Cold starts... I now can get the stove going in 15-20mins with a crisscross stack of small splits, using a torch to ignite. Once the center of the stack starts burning at a rate where the torch is no longer required, I remove the torch and close the door. I give the stove 20 mins and then add 3 more splits on the sides. Splits are smaller. This I find allows the fire to grow from the center without adding to much fuel. After about an hour, I can load the box up.
Warm starts... rake the hot coals to the front, stack splits to the back and close the door. Depending on the outside temps and the load, takes about ½ hour or a bit longer for the stove to take off and almost no smoke out the stack.
Now I am still having random back puffs. They usually happens when the draft blower and turns off the first time. Fills the basement with a cloud of smoke. Turning on the draft blower helps eliminate the back puff, however it can still happen. Very frustrating to deal with!!
I have worked a lot with the folks at HY-C, they have from day one always returned calls, visited my house and provided suggestions. They have agreed to switch out the stove for the another model as we can’t seem to find the right formula for my application. There is no doubt this stove takes time to dial in and learn how it works. It is a budget stove with a very sensitive design. I think for X amount of applications out there, this stove would work as advertised. However, for some reason, it just can’t get over the back puffing hump.
One thing that I have noticed as I have become more educated is my stack doesn’t burn clear. When the stove should not have any smoke from the stack, my application has a small cloud of condensation which quickly evaporates into the air. Thinking of pouring vermiculite between the SS liner and the clay lining, see if it helps increase the upper stack temps.
Also, as far as I can tell, I am not having the creosol build up like I did last season.
Question. Where is your thermostat set at when firing? I had the exact same issue and set mine to where the blower will not shut off for a good hour and that cleared up. Works good when the house is down to 65. My biggest issue so far this year has been keeping the house consistent on temp. I don’t mind the 65 in the morning but, I have to get it to 75 before I can set the thermostat to 72 or it will puff.
I attribute it to the lack of air when it is idleing.
