Nope. Article ends with the Chief saying it was an unusual cause . . .
The link I follow has that comment, 2 more pictures and then a heading and more text where he explains what he found. Maybe the entire page isn't loading for you
No that is a direct connect. Slammers involve no pipe.I saw a show many years ago where they put an insert in a masonry fireplace and ran only a few feet of pipe up into the chimney. Is that a slammer?
But it was just stuck up there loose. Just enough to get past the old damper.No that is a direct connect. Slammers involve no pipe.
That is a direct connect just a very poorly done one. A slammer is just slammed into the firebox with no connection.But it was just stuck up there loose. Just enough to get past the old damper.
It may be a definition but it isn't a correct one
Similar problems but not the same. A slammer allows allot of dilution air around the surround making the problems worse. Doing it this way it can be sealed well so no dilution air. It is still bad but not quite as bad.Because it's not pushed forward a couple feet? Same effect, same problems.
I've seen quite a few old houses where the fireplace or fireplaces were walled, one house had 4 in the middle of the house all walled off. Why? Who knows why people do what they do.It is not a slammer. Many installation manuals permit a section of pipe into and above the smoke chamber, stopping inside a clay lined chimney. The creosote DEFINITELY can drop down onto a block off plate, if installed.
BUT..... The cause of the fire was the "ENCLOSING" of an "EXTERIOR FIREPLACE" during the addition 100 years ago. Presumably, the fireplace was modified (bricked off), and the chimney was improperly modified via the vent pipe with no debris catch/stop and/or presumably, no way to properly and effectively remove the creosote below. And, apparently, safe clearances to combustables were not maintained 100 years ago. What I don't understand is when was the fireplace blocked off, and why. Did they install a gas furnace 100 years ago? Or, did someone have the bright idea to block it off and install a stove 10 years ago?
"...Nearly a century ago, an extension was put on the home and the fireplace*** was closed in***, but remained connected to the chimney, he said.
Some time later, a wood stove was added to the original part of the home and the metal pipe tapped into the chimney, loading it up with creosote over the years, ..."
Because they suck heat out of the house.I've seen quite a few old houses where the fireplace or fireplaces were walled, one house had 4 in the middle of the house all walled off. Why? Who knows why people do what they do.
This is one good reason why a fireplace should be tagged in some way, to notify owner/ potential users that a modification has occurred.I've seen quite a few old houses where the fireplace or fireplaces were walled, one house had 4 in the middle of the house all walled off. Why? Who knows why people do what they do.
That makes sense. Probably did it once they had central heat.Because they suck heat out of the house.
Yes, but what alternative heat source, 100 years ago, was available, as RYAN723 pointed out.Because they suck heat out of the house.
Yes and quite often the furnace is run up through one of themThat makes sense. Probably did it once they had central heat.
Coal furnaces and coal stovesYes, but what alternative heat source, 100 years ago, was available, as RYAN723 pointed out.
 Obviously, they never consulted anyone on this site before they made the mods and installed the stove
Obviously, they never consulted anyone on this site before they made the mods and installed the stove .
.It is not a slammer. Many installation manuals permit a section of pipe into and above the smoke chamber, stopping inside a clay lined chimney. "
Yes I have never seen a direct connect done properly. I don't even know how one would go about doing it properly.The part missing from that statement is that there must be an airtight seal between the pipe and the clay liner. Everybody, virtually everybody, seems to ignore that little comment.
