The Summit insert is in. The liner and block off plate are in. I'm working on the top of the chimney now. PE says a 15 foot chimney is minimum. I measured my liner and I have 15 feet one inch. This is a ranch house with the chimney epoxed to the outside on only one side, and its the skinny side. I'm concerned about draft. I have not insulated the liner. Should I just put the cap and top plate on and be done with it? Should I buy another terra cota flue tile and extend the chimney another foot? Would one more foot make much difference? Should I just see how it does and if I have problem insulate it next year?
It doesn't get really cold here and I'm concerned about draft. I just looked at our average temperatures and heres what I found.
Month low high
November 35 57
December 28 46
January 24 41
Febuary 25 46
March 33 56
As you can see, I'm going to be doing alot of burning when the temperature is in the 40's.
Thanks,
Karl
Month low high
November 35 57
December 28 46
January 24 41
Febuary 25 46
March 33 56
Thanks,
Karl
