I had been waiting on my sweep to extend my stacks 3' and put a coupling on a join I discovered right at the cut-out flue on the Nashua downstairs, and all that got done this week.
I bought a bag of Roxul and used about two bats to stuff up above the Nashua, and it wasn't too tough. So the next day I decide to do the insert. The Rockland is a crazy install in a massive masonry wall. Well, I got the sheet metal cover off and crawled behind the insert.
If my knees bent the other way I could have stood up in the cavity!! It was huge in there. No WONDER I've never been able to get much heat out of that insert. I couldn't get positioned to put Roxul up where the liner went to the flue, so I had to form a type of ceiling using a ledge and a few vertical pieces of Roxul to make sure it doesn't come down. I have another clever buddy and we'll rig up something permanent. Probably ended up with three unused bats equivalence, so quite a lot fit easily in there with much space left over.
Lit the first fire of the season tonight and it seems to be a big difference. I also went with Jatoxico's suggestion to pull the unit forward a slight amount. That's letting a lot of heat get out from the surround. Maybe, maybe, MAYBE I'll start to see this thing meet expectation.
Jotul buyers, if your seller/installer doesn't want to install a blockoff plate, they are no-good %^@@# sonsa'*&*&^**!! (<--Everything but a child of God) It'll turn out to be critical in my case.
Thanks to the forum!
![Finally insulated my Jotul Finally insulated my Jotul](https://www.hearth.com/talk/data/attachments/167/167447-5cb80b4cedc9bb3f33c3af92f3bc2693.jpg)
![Finally insulated my Jotul Finally insulated my Jotul](https://www.hearth.com/talk/data/attachments/167/167445-e5bbcf27f0236473f4a96dcef34a9ba8.jpg)
![Finally insulated my Jotul Finally insulated my Jotul](https://www.hearth.com/talk/data/attachments/167/167446-9b81dfb5ac7f8367b30843d2df4b790b.jpg)
![Finally insulated my Jotul Finally insulated my Jotul](https://www.hearth.com/talk/data/attachments/167/167444-47220c574fd7acfbf5c36d27195a3b20.jpg)
![Finally insulated my Jotul Finally insulated my Jotul](https://www.hearth.com/talk/data/attachments/167/167442-912238281c03c3a68381fba787334fdb.jpg)
![Finally insulated my Jotul Finally insulated my Jotul](https://www.hearth.com/talk/data/attachments/167/167443-1f20a95179616e146007b52f8f115e12.jpg)
