Final Decision (indecision!) between Jotul F55, Hearthstone Shelburne or Manchester, and Woodstock Ideal Steel
Also are you certain the flue is covered under the tax credit? I installed a new flue this year for my hearthstone which is a tax credit stove, but I purchased the stove in 2020...
would I be able to get anything back for the chimney?
Speak to your accountant. I suspect not. The credit is on the entire installation, including flue system, but not for a retrofit afaik.
I understood that it had to be for a complete installation; the credit is associated with *the stove* - and associated stuff (flue), it is not for *the flue*.
If a flue a year later is valid, where is the the limit? 2 years, 5 after the stove?
Hence I think you are out of luck.
I wonder what the cheapest tax credit eligible stove is 🤔
I believe it is only covered if the work is done at the same time as the purchase of a new EPA stove. I'm not 100% sure though.
Woodstock has a good summary re EPA credit if that's useful?
Reactions: Rob_Red
