This will probably seem elementary to most of you but,... What is the proper use for felling wedges? What do you use them for? Any tips?
southbound said:I use mine to fell trees
You may be able to find what you are looking for here.........
http://www.osha.gov/SLTC/etools/logging/manual/felling/cuts/notches.html
Kenster said:southbound said:I use mine to fell trees
Great resource. Thanks.
I don't quite understand the use of the wedge to prevent binding. To do that, wouldn't you have to knock the wedge into the cut behind the saw? Seems like the saw would have to be well into the cut before you could push a wedge into the same cut behind the saw.
wood spliter said:I use the plastic wedges for cutting the lower big rounds on the trees. If you hit the plastic wedge it will cut it a bit but your blade will be OK. You also may need to pour a little oil on the bar depending on the round size. In MHO wedges are not great for felling. If you need a wedge the tree already wants to go the wrong way. In that case you should use a rope or climber depending on lean and weight.
wendell said:wood spliter said:I use the plastic wedges for cutting the lower big rounds on the trees. If you hit the plastic wedge it will cut it a bit but your blade will be OK. You also may need to pour a little oil on the bar depending on the round size. In MHO wedges are not great for felling. If you need a wedge the tree already wants to go the wrong way. In that case you should use a rope or climber depending on lean and weight.
Sorry, but wedges are made for felling. If you don't know how to use them properly that's one thing but why would I climb or tie off a rope when I can drop the tree exactly where I want using a few wedges?
If you think wedges are not good for felling , you'd sheet yur panties watchin me kill back and side leaners. :coolsmile:wood spliter said:I use the plastic wedges for cutting the lower big rounds on the trees. If you hit the plastic wedge it will cut it a bit but your blade will be OK. You also may need to pour a little oil on the bar depending on the round size. In MHO wedges are not great for felling. If you need a wedge the tree already wants to go the wrong way. In that case you should use a rope or climber depending on lean and weight.
advantageousLEE said:If you think wedges are not good for felling , you'd sheet yur panties watchin me kill back and side leaners. :coolsmile:wood spliter said:I use the plastic wedges for cutting the lower big rounds on the trees. If you hit the plastic wedge it will cut it a bit but your blade will be OK. You also may need to pour a little oil on the bar depending on the round size. In MHO wedges are not great for felling. If you need a wedge the tree already wants to go the wrong way. In that case you should use a rope or climber depending on lean and weight.
I always have 3 and if I'm workin around houses with big timber I'll use 8.
Flatbedford said:Get this book.
http://wesspur.com/images/treegear/boo169-365.gif
It is all in there. Clearly explained with great pictures too. I have been through it a couple times and surely be through it a few more times.
I would not send a climber up a dead tree. I did not know that was one of the many variables we were talking about. In My Humble Opinion I think ropes are a better way to go. You can get a great amount of mechanical leverage with pulley's. Most of the tree work I have done has been urban. When there is a lean or in the woods I notch and drop.wendell said:wood spliter said:I use the plastic wedges for cutting the lower big rounds on the trees. If you hit the plastic wedge it will cut it a bit but your blade will be OK. You also may need to pour a little oil on the bar depending on the round size. In MHO wedges are not great for felling. If you need a wedge the tree already wants to go the wrong way. In that case you should use a rope or climber depending on lean and weight.
