So i bought a cheap'ish Turbro 12k btu 240v minisplit off amazon this past summer. Installed this fall. I have a couple year old 50 gallon heat pump hot water heater in the basement. I installed the minisplit head about 5 feet away from the water heater and the goal was to provide heat to a room in the basement and to provide heat to the hot water heater. No other heat source is in the basement. So far so good. The heat pump hot water heater has never switched over (to all electric) yet this winter and it has been cold here in Wisconsin. Also last winter i had an issue with the coils frosting up very badly--no issue this winter. I will say we've had to space out showers at times (family of 5). In the morning 3 can easily take a shower and be fine. IF i did it over i'd go with a 80 gallon tank just because of family size. I do have it set to 130F and have a mixing valve i want to install so i can set it at 140F. Its pretty neat to think that the heat in the tank is coming from outside all winter, although I doubt the COP of this setup is that great at very cold temps. In summer the hot water heater pretty much cools/dries the basement so its win-win.
I only bring this up because i've seen outdoor units that heat water...this is basically doing the same thing (but not as efficiently?) Much cheaper i would guess (Turbro model qualified for tax credit)--$500 into it..Heat pump hot water tank was cheap home depot deal i found ($700 at the time). Just thought i'd share.
