Started back in '85 with an Englander 24 Radiant, a plate-steel step-top N-S burner. Good stove but didn't work too well on Red Oak that was only in the stack for 3 months.
Around the year 2000 came a '96 Dutchwest 2460, a cast iron cat stove. That one didn't (doesn't) like wet wood, either,
since it's a cat stove. Both of these stoves kept us from freezing to death, barely. I knew I should have been stacking my wood sooner, but that seldom happened. One year I got some White Ash from a neighbor and thought "Hey, this stuff is burning great." Didn't fully comprehend that it was that it was due to the wood being drier.
Once I got dry-wood religion here, about seven years ago, I got way ahead on stacked wood, and there I have stayed ever since.
The Dutchwest got me hooked on having an ash grate in the bottom of the box, with a pan underneath. None of the hassles associated with the Englander and shoveling, like pushing coals around in the box, trying to contain the dust, and carrying out a blazing-hot load of "ash" that was half coals. With the grate, just swirl a poker through the coals once every few reloads, and that's all you do until it's time to pull the pan and dump it. As Seasoned Oak hinted, to have a window was amazing, both for the beauty of the flame and the operation of the stove. The DW window
is small, though.
I wasn't too familiar with Woodstock stoves until my SIL picked up a used Fireview for $350. It had clearly gotten hot but was not seriously damaged due, I think, to its heavy duty cast iron construction. I had to replace the combustor scoop, but the bypass was undamaged. Woodstock parts don't cost you an arm and a leg...barely a couple fingers.
The Fv had some air leaking into the box, probably from seam cement being loosened when it got hot. Luckily, that's pretty easy to fix to an acceptable degree. My Keystone had some air leaking from one seam, right from the factory. In light of that, I think I'll avoid any seamed stoves, be they cemented or gasketed, and that my next stove will be welded plate-steel. There are a few plate-steel cat stoves out there, but as far as I've seen, only Woodstock has the top-flight engineering, quality materials, price, ease of service, and customer support that I'm looking for. And the ash grate...and top- or rear-venting...and hybrid tech-knowledge-y.
IMHO, no other plate-steel stove has it all, to the extent that the Woodstocks do. One thing they
don't have is blowers, only a modest amount of convection built in, so they may not work as well as a blower stove in a chopped-up floor plan where you need to move a lot of heated air.
I’m yet to find a stove that will out perform a Blaze king, not even close...Hands down the best stove I’ve had to date.
Yes, but you haven't yet gotten the Woodstock steel stove that you have been threatening to buy, so your testimony doesn't carry quite as much weight as it might.
Well rest assured, BK does not have the issues with failures like cat stoves from the past.
No, they've come up with their own unique set of failures that no one else even thought of.
If I didn’t have a Blaze King Ashford, I’d get a Woodstock.
Ah, don't sweat it, it probably won't be all
THAT horrible...
