favorite pellet 2014/2015
JRA
343
north shore ma
These were my top three first year burning. 1. Okanagan fir really high heat and ash was non existent. 2. La crete great heat and light fluffy ash. 3. Logik-e consistent heat and light ash.
Hoping blazers will top these I have three ton coming next week! Never burned them before, however followed reviews on this site and this year was the first opportunity I had to purchase then in my immediate area.
I liked my Somersets and got them again this year. I have read good reviews on the Blazers too.
AWF(American Wood Fibers) White Pine.
I thought these burned as well as the Okie Golds...but cost $60+ less per ton.
Reactions: Peterfield
Well last year i'd have to say Red Lettered Lignetics-Lacretes-Spruce Pointes.This year i'm going with a ton of Hamers and two tons of Vermont Wood Pellets.
Lignetics, Lacretes new this year...
Energex Golden low ash pellets are my stable each year
  • [Hearth.com] favorite pellet 2014/2015
Reactions: JRA
A local dealer of mine was supposed to get these and I was wanting to try them, they were even posted on their website for months with no price next to them. Finally they took the m down in June and I called energex directly. They told me due to availability of raw material that they wouldn't be shipping much if any out of PA. Hopefully they show up in mass at some point, reviews I have seen are good.
Reactions: Tonyray
Wanted to try these but to my knowledge they are not available in mass
I liked these as well, they showed up at home depot last season and I burnt about 10 bags, would definately add a ton of this to the stash if they show up again. Heat was great a little sooty.
My favorite so far has been the Bear Mountain doug fir pellets. Burned well and produced almost no ash at all. I only had to clean things out every 2-3 weeks or so. I burned a couple of tons of them 2 years ago but I haven't been able to find any for a decent price since that batch. I got these for $200 a ton 2 years ago with free delivery.
I tried the Cleanburn doug fir pellets but they produced a lot of white powder that I am pretty sure was salt. I think they are using driftwood or logs that spent too long in the ocean or something. They also burn really well and made no ash but I didn't like the idea of my iron/steel stove being filled with salt and pellet smoke which is mostly steam and CO2. Sounded like a great way to corrode out the burning pot. They were also pretty expensive at about $300 per ton. Cheapest I've ever seen them was $275 per ton.
My second favourite is the Eagle Valley softwood premium pellets. They burn well, nice and hot and light fast. They make a bit more ash than either of the doug fir pellets I've tried but none of that white "salt" that the cleanburns made. I burned about 4-5 tons of them last year and I just loaded up with them again for this year. I got them for $200 a ton both times with free delivery. With these, I have to clean out the stoves about every 10 days but I tend to do them once a week because I always have time to do it on Monday mornings and they run longer on the weekends (thermostat is set for higher temps during the day because we are home). Some weeks I was too busy or forgot and I was able to go 2 weeks between cleaning but things did get a bit messy and I started having some issues with ash blocking the igniter in one of my stoves. The other stove didn't have problems but it has an agitator in the burn pot and the igniter is like a little heat gun so it never gets plugged up because it's blasting air out the port. I find that these burn hotter than the doug fir pellets but all in all, I use the same amount of pellets either way.
From what I can tell, hardwood vs softwood only matters for cordwood and even then, it's a case of BTU per pound of wood being about the same but hardwood being a LOT heavier. I did notice that the bags of doug fir pellets are quite a bit smaller physically than the softwood pellets but 40 lbs is 40 lbs. My stoves do have 2 independent settings for wood type (soft or hard) and each has its own feed trim and combustion air trim setting. I accidentally burned softwood pellets on the hardwood setting once and it made a LOT more ash and a LOT of smoke (took a long time to clean the glass off afterwards!!) So it is important to recalibrate things if you switch and you don't have a sensor in the stack to auto calibrate things!! I wonder if this is the reason why a lot of people have a really strong preference for one type over the other, if they didn't recalibrate when they tried a new kind and their burn was totally off and so they got a bad impression of the new kind of pellets?
With my old woodstove before I replaced it with the pellet stove it made a HUGE difference because I was limited by the volume of the firebox. If I filled it with Maple or Arbutus it would burn a LOT longer than if I filled it with pine!! I suppose that with the doug fir pellets I was probably getting away with only refilling the stove hoppers every 1.5 to 2 days on average days and with the softwood pellets I have to fill them every day on average days and twice a day on cold days, so there's that.
I also (unfortunately) tried some FireMaster pellets I got at home depot. They made a LOT of ash and really made the inside of the stove dirty. I had to clean it all out about twice a week !!! never going to try that again. I've heard similar stories from a lot of people about those. Yes I did try to recalibrate it and adjust the feed and air trim but even with them set perfectly, those pellets were like burning those rubber pellets made for old tires that they use in some playgrounds.
Hammers...hot, clean burning, consistent size and not terribly expensive. Not much more you can ask for. I liked them better than Lignetics but never had any issues with Lignetics, just noticed that the Hammers were a tad cleaner and a whole lot hotter.
Energex only produces the Goldens for a short period in the year and that's it.. most dealers like mine get to order 1 time and 1 time only.
think of seasonal beers that they produce for a limited time each year..
On the bag it states that they are only sold to certain " Hearth dealers" .. for what it's worth..
Reactions: JRA
My dad basco(?) stove burns at its best with softwood so we shall see what I get.
Reason I will be going with the same stove is my father lives in my other house and id rather make it easy by having the same pellets rather then 2 different types.
Last year I burned Uncle Jed's in shoulder season. Bear Mountain during cold months. The best I have ever burned. Bear Mtn. Very hot and very low ash. Only downside is they are expensive to buy in the midwest.
Looks like I got myself some lacretes for 265 a ton. Jumping on this no questions.
think I paid 309.00 here for Lacretes..
Spruce Pointe, at $289/ton, performed best for me if I balance price, heat, and labor required...gave good heat and required not a lot of scraping in my Enviro M-55i. N. Idaho Energy Logs were a joy--in terms of low ash and so little scraping--but cost what a fir pellet should around here [$349 last fall].
LG Granules gave noticeably less heat, but required little scraping and not that much ash.
LaCretes and Turman were OK for me, but I didn't get more for this year…I will try Vermonts and Blazers this year alongside Spruce Pointe & some LG Granules for shoulder season. I'm enjoying playing w/ different pellets as a relatively new stove owner.
Reactions: JRA
New as well going into second season burning I agree about the lgs although la crete burnt well for me. I burnt n idaho as well and they were great through the first 10 bags I tried then the ladder half of the season I bought 10 more bags and they weren't nearly as good. This year I have 3 ton of blazers coming and getting one ton of corinth
Hello Bags, hope you could share what the price is out there. We are paying 259 on the East Coast mid-atlantic Maryland.
Thanks
Edward
If I may ask where ??: thats a great deal
Lowes at Dover Delaware. Lowes marketing and warehouse send pellets any kind any where no rime or reason.
Tried for years, but they are just to smart for us old guys.
My store in salisbury, md just don't care,they only have one number for pellets and that is 87059,
and all the stores sell all brand under the same number. Go figure hugo or mercedes, same number same price.
Somerset's here in Iowa are 218.00 a ton,I picked up 2 ton as I'm already sitting on 1 ton from last year.
Great price. It is 674 miles from 42503 KY to19901 delaware zip codes not bad for trans.
Thanks
Edward
I'm jealous of some of the prices you guys are finding! Here's what I found this year in Southern Maryland - Calvert County.
Lignetics-266
American Wood Fiber-339
Hammers-299
Somersets-325
Omalley-269
Statesman-289
Forest Pride-259
I used Somersets and American Wood fiber last year. I liked the Somersets the best-good heat and low ash.
