On the suggestions I got here, I took a tower fan we had around, pointed it into the door of the stove room (but set it outside the door), and turned it on super-duper low so you can barely tell it's running. The Sierra is munching on small BL splits, temp on the stovetop running 500-550. Not an especially big fire- the box is less than half full.
The heat started pumping out of the stove room like I wouldn't believe! Inside 30 minutes the adjacent dining room jumped from 70 to 75, and I can even feel a warm draft at the top of the center stairs on the 2d floor.
I shut off the heat pump at 9am... Mrs. Blue hasn't noticed yet.
