Glad its working nicely for ya. We seem to have 3 members that have the 50F and no complaints what so ever! I'm liken them odds!![]()
You've got to stop reading about other's toys, it only gets you in trouble with she who must never be made mad (Remember she has the cast iron skillets and lead weighted rolling pins.)
Folks what we have here is one pellet pig trying to save another pellet pig's bacon from being rendered by the boss lady.
I have 1 compalint..
When it auto cleans, if the house is already at temp, it overheats the house for about 2 hrs.
It takes about 40 minutes for the entire process. But it CRANKS on level 5 for that duration.
So my 73° home, shoots to 76°-78° in that 40 minutes and slowly drops over the next couple hours. When its around 20°-25° outside, the furnace stays on level 1 (feed and air trims at 5 of 5). The last few days, its been coming off of Low and Hitting High (I have it set to level 3 when calling for heat). Actually, been about 30 min On level 3 and 30 to Low.
Oh and a Bigger distribution blower (o.k. thats 2 complaints. But i dont NEED it) would be nice. I only have mine ducted to one Main trunk, or 50% of my ducts. It works awesome like this, but if it had a 1,000-1,500 CFM blower, I could turn the other trunk on (open damper).
Oh well... Its 71° and climbing here. I turn all heat off while we are gone. I tried it last year, when it was warmer, and it worked. Now it just takes a couple hrs to reach stat temp. No biggie. I just run the wood eater at Full tilt![]()
Sounds like you need the PF100 and I can steal the 50F!jk!
How often does it auto clean?
Depends on the fuel setting. There are 10 settings (Premium Pellet being #10/The longest time between cleaning). It is around 9-11 hrs, best I can see. I manually do a "Pot Change" (self clean is called a Pot change) about an hour before the kids bedtime. That way there doors can be wide open and let the heat out.
Jay, I can read you like a book....I see you asking all these questions of the guys with the furnaces....you're building up that notebook, and one of these days....WHAM....there's going to be a new furnace in your basement.Sounds like you have the curve all figured out. Thanks for sharing the info bro!
My wife sent me an email at work about 4:30 saying it was 71 in the house, she was sweating and wanted to know if it was OK to turn the furnace down to 2. I loaded it with Pro Pellets this morning. Maybe those were burning hotter than the 'sets. It was a bit warmer today (14) but not that warm. It's a balmy 8 now and the house is at 70.
The self clean on mine isn't as hardcore as Dexters. He has the newer LCD control board. Mine is generation 1 with LED's. The top burn plate comes out on mine for 5 minutes and builds the new fire. It runs on level 5 for 5 minutes then the bulldozer pushes the junk out of the lower burn pot. The top plate retracts, the fire drops to the main burn pot and it runs on 5 for 10 minutes. 15 minutes start to finish. Seems to do it every 9-10 hours. It does jump a degree or so.
I love the furnace though. Wish I'd gotten one years ago. Only problem is that I want the pellet grill that Fahrenheit makes too. There may be another trip to the factory for me come springtime. That will be a bit harder to sell to the wife.
How's the Fahrenheit been doing?
What level are you running? Are you using a Stat?
Is the burn still good? Good grey/white ash?
You gotta a smokin deal and a killer looking set-up.
